Fuel Pressure Help!
Old Jan 29, 2008 | 06:58 AM
ScreaminEagle's Avatar
Fuel Pressure Help!
I filled up my tank a few days ago and the next morning on my way to work it was acting like I was running out of fuel. I drove around a little bit and it seemed to work itself out. I still have a little hesitation. Also, I am running 2-stroke oil at about 1oz per gallon for lubrication.
1) Has anyone ever gotten a bad tank of fuel?
2) Is there a place that I can hook up a temporary fuel pressure gauge on my truck? I'm running the stock VP-44.
Old Jan 29, 2008 | 07:19 AM
b4wheeler's Avatar
There is a schrader valve on the inlet line to the VP-44. You can get a fuel pressure tester from Auto-zone or Advance Auto and hook it directly to this valve. The one that I have is made by Actron. This will give you the pressure going into the VP-44. If it is low, look first to your fuel filter, then the Lift pump.
Old Jan 29, 2008 | 07:51 AM
91rangerturbo's Avatar
PM sent screaming eagle
Old Jan 29, 2008 | 07:59 AM
nkennedy's Avatar
Spend a hundred bucks on a permanent FP gauge. Best money you can spend on a second gen.
dodgeguy71
17
Jan 19, 2012 12:52 AM
MoparRiggan
Jan 5, 2006 11:09 AM
mtl0727
Nov 5, 2005 06:47 PM
darrenG
Jun 28, 2005 07:43 AM
Flatty
Jan 5, 2005 02:50 PM
