Fuel Pressure @ 2 PSI @ WOT FIXES?
Old Mar 31, 2003 | 06:52 AM
hellotbone's Avatar
Hey guys as the topic says Im getting a low Fuel pressrue at WOT. I get about 14 and Idle and 12-13 in cruise but WOT its all gone I get about 7-8 with a heavy foot. Whats a good fix for this?
Old Mar 31, 2003 | 07:15 AM
hellotbone's Avatar
Re:Fuel Pressure @ 2 PSI @ WOT FIXES?
On the side note is the cummins pump any better? The one I hear guys buying from cummins direct? If so what is the part number on that and relitive cost?
Old Mar 31, 2003 | 07:27 AM
pappyman's Avatar
Have you thought of puttin on a pusher pump ??
Old Mar 31, 2003 | 07:37 AM
hellotbone's Avatar
I am open to all suggestions from everyone with part numbers and costs. And results.
Old Mar 31, 2003 | 10:21 AM
BigBlue's Avatar
Well, you can put a pusher pump on. Install the PE4200 pump, a Holley Black, or go with the Cummins pump. I did the Black and I get 16.6 at idle and 13 at WOT with pump wire hoooked up. ;D You can get all of it from Rod.
Old Mar 31, 2003 | 10:37 AM
dodgeram's Avatar
talk to rod about the new fuels system upgrade that uses the stock pump .......don't know if he has it ready yet <br><br>BTW with the stock fuel lines I was running 16 idle, 12 cruise &amp; 5 wot<br><br>I just upgraded the line from the pump to the filter and I run 16 idle, 14-15 cruise and 10 Wot ......<br><br>can't wait till all the lines get upgraded when rod gets that new kit done<br><br><br>he also had a wicked looking replacement pump he was going to test, ask him about that too <br><br>
Old Mar 31, 2003 | 10:42 AM
hellotbone's Avatar
Whats with the cummins pump.
Old Mar 31, 2003 | 11:00 AM
banshee's Avatar
Jaime,
if you're interested in going big then I'd suggest the PE4200 like BigBlue mentioned. Andy &amp; Doug at Advanced Diesel (www.smokindiesel.com) sell a complete kit with the lines, fittings, pump, wiring, and all necessary hardware. It's probably more expensive than most setups, but it's probably the best to date. With my setup I can't pull my westach gauge off the peg. If you're interested in staying with the stock lift pump then I'd suggest going to big banjos and a big line kit. I talked with Timinva a couple of weeks ago, and he's running a stock lift pump with the big lines and banjos along with DD3s and a PM3. He said the banjos helped only a little, but the lines made a big difference and I think they added 5 or 6 psi at WOT. The stock lines are really restrictive... especially the line from the lift pump to the filter housing. Like the others suggested, I would give Rod or Andy and Doug a call for the lines.
John
EDIT: here's the link to ADT's fuel web page:
http://www.smokindiesel.com/Dodge/24...system_24v.htm
Old Mar 31, 2003 | 11:02 AM
fahlguy's Avatar
Jaime,<br><br>The bitg thing is to get rid of your junk stock lift pump. Also stay away from carter pusher pumps, the are junk. I know people have had some good luck with them, but they just do not last. <br><br>If you plan adding more HP in the future, I would get rid of your banjo bolts, upgrade the line from the tank to -8 or bigger, and use a PE4200. You may also want to consider a 1/2&quot; stanpipe for the tank also. There are a few people out there offering kits, or you can build your own, which is very simple to do.<br><br>I currenty l have the above system and and pushing more fuel than you, and I never drag my fuel PSI below 16 psi, and that is after fuel filter. Idle is around 19-20 PSI<br><br>I am just trying to save you some money, and some time of not having to do your fuel system twice!<br><br>Good luck!
Old Mar 31, 2003 | 11:20 AM
hellotbone's Avatar
Where can I buy just the PE 4200? I can upgrade the lines myself when I get the pump here and figure what I need. I should be able to throw the stock pump away mount the PE and hook up the bigger lines correct?
Old Mar 31, 2003 | 11:35 AM
TxDieselKid's Avatar
You have been lucky not to have the pump go out yet with all those bombs. <br><br>The PE4200 you can get from several places, but the place I heard of selling them first is Advanced Diesel Technoligies. Their website is www.smokindiesel.com . Andy and Doug are their names, and they were the first ones to really try this pump, and talk to the maker about warrenty, and what all we needed.<br><br>Andrew
Old Mar 31, 2003 | 11:55 AM
hellotbone's Avatar
Im trying to find the pump from the manufacturer anyone know who makes it?
Old Mar 31, 2003 | 11:57 AM
The PE stands for Product Engineering, which is who makes the pump.
Old Mar 31, 2003 | 12:01 PM
banshee's Avatar
Jaime,<br><br>here's PE's webpage for their fuel pumps:<br><br>http://www.productengr.com/Fuel_Pumps.htm
Old Mar 31, 2003 | 12:05 PM
If you order it from them, make dead sure they know that it's going on a diesel, so that way SHOULD it die, and you want some warrenty, they can handle it. That is the reason I suggested ADT.
