Fuel Press w/ COMP
Old Jul 31, 2006 | 09:46 PM
Awall's Avatar
Fuel Press w/ COMP
I am putting an Edge COMP on my stock truck and my fuel press now is 12 at idle and 9 WOT... do i need an additional LP??? and if i do, what kind should i get?? thanks, Awall
Old Jul 31, 2006 | 10:21 PM
01smoker's Avatar
9 psi at WOT sounds ok, but if it starts to get lower than that, I would get a FASS System. You won't have any more Lift pump or fuel pressure issues after you get a FASS.
Old Aug 1, 2006 | 11:27 AM
Awall's Avatar
how much is the FASS system?
Old Aug 1, 2006 | 11:38 AM
Diesel-Dan's Avatar
Here ya go.....
All you would need is the following:
FASS 95/95-1008
OR
FASS 150/95-1008
OR
FASS HPFP-95-1002
Old Aug 1, 2006 | 11:58 AM
Awall's Avatar
thanks, awall
Old Aug 1, 2006 | 04:03 PM
DMcPherson's Avatar
mine was the same 9psi WOT, comp came I could get 4-5. fass is WAY to pricey for me so I used a holly black pump and fleetguard waterseporator prefilter, (kind of like a fass) for a whole lot less. now I cant get less than 15 WOT
Old Aug 1, 2006 | 04:56 PM
yarddog's Avatar
If you're seeing 9 WOT stock, the comp will pull it way down. You definately need to upgrade before you tap the wire. Search "Walbro" as a great and much cheaper alternative to the fass.
j
May 16, 2007 08:11 PM
Timinva
Dec 16, 2002 05:05 AM
YJim
Dec 12, 2002 08:18 PM
Commatoze
23
Nov 22, 2002 02:10 PM
Cat Cracker
Oct 13, 2002 12:54 PM
