fuel issue?
fuel issue?
I have a PPE 160gph lift pump and at idle it is set to 15psi. Yesterday it was running louder then normal and my idel psi is now 13. Could a dirty fuel filter cause this? It seem like the pump is working harder with less fuel pressure. If I get into the throttle some it is easy for it to drop to 8-9psi but before I would have to hold the pettle down for a while to get it to 10psi. Any thoughts? Thanks in advance!!
Running louder does sound like a filter restriction or something like that. Also may be an air leak into the pump.. Not sure on how these pumps are hooked up, but I would just take a quick boo at all the connections to be sure everything is snug and then pull filters..
ok I changed my fuel filter and it did not help out at all. What to check next? It is still at 13psi at idle and when I drive it gets sucked down to 8-10 psi and when I let off, it slowly builds back up. It use to snap right back to 15psi but now it takes about 3-4 sec before getting to 13psi. Any ideas?
Those pumps don't work well for us. PPE's pump is a private label pump that is made by Essex Industries http://www.essexind.com/
I beta tested the pump over three years ago and the pump did not work with diesel at the time.
thanks for the input I checked out the site and looks like I need to check my strain screen on the pump. I think the pump is still working good it's just working harder from some kind of restriction
When mine went it was making a louder noise, screen was clean. The pump just died one day on the way home from work. It was a real quite pump up until it got sick. I took the pump apart and the inside of the motor was rusty.
Here's my thread from back in 04 https://www.dieseltruckresource.com/...ft+pump&page=4
dan123dbl
Feb 13, 2015 05:47 PM
