Front shocks
Old Aug 30, 2004 | 11:00 AM
crobtex's Avatar
Front shocks
What is the trick to getting the bottom bolt out of the front shocks? The top don't look too bad, but the bottom looks a booger!
CR
Old Aug 30, 2004 | 11:08 AM
DuaneWKKC's Avatar
Uh, bottom bolt was easy.... take nut off first, then slide bolt out with large tool to help if needed. On mine, left front was a bugger, not enough room to get shock out thruough the top. Ended up cutting that shock in two, came right out then. Slide new shock in first, then rebolt shock tower down, then cut tie holding shock compressed.
Good luck..
DuaneWKKC
Old Aug 30, 2004 | 11:23 AM
crobtex's Avatar
The shock tower is the bracket that hold the top of the shock?
When looking at the bottom bolt, it looks like you can get a socket on the front side, but the back side looks a little tough.
Old Aug 30, 2004 | 01:11 PM
Cowhand's Avatar
Backside had a little "arm" attached to the nut that sticks out to keep the nut from turning. At least mine does.....
Old Aug 30, 2004 | 03:43 PM
herb's Avatar
i took a new set of bilstein shocks up to our local "muffler man " shop this afternoon and had them put them on (10.00 and a box of donuts)
Old Aug 30, 2004 | 11:14 PM
crobtex's Avatar
Let's see now..................how far is it from Texas to Michigan?
Old Aug 31, 2004 | 12:03 AM
Cowhand's Avatar
More than $10 and a box of donuts.....
whosdunit
Jan 11, 2017 01:54 AM
EverydayDiesel
Aug 19, 2007 09:38 AM
DanTana
Aug 12, 2004 11:54 AM
Turbo Deeezle
Jun 30, 2004 06:18 PM
silverram323
Oct 10, 2003 12:19 AM
