Front Control Arm Bushings Energy?
Old Apr 23, 2009 | 08:47 PM
the496rocket's Avatar
I am in need of new control arm bushings for my 99, I wanted to get the Energy Polygraphite bushing set, but saw a post on here that someone ordered the 5.3132 kit which says fits 99-02 but when he got them instructions says it fits 00-02, and they would not fit his truck, bolt sleeves were too large I.D. Can anyone clarify this? The 5.3120 says it fits 94-98 trucks, I know in 94-99 4x4 2500's had the Dana 60 in the front, and in 2000 they switched to American Axle, so the numbers done make sense either, if the larger bolt holes were on the american axles from 00-02, any help please?
Old Apr 24, 2009 | 01:37 PM
smokinram99's Avatar
i have ordered part# 5-3131G and dont fit my c.arms...too bigger for my bolts.. I need 5-3120G for my 99. little bolts. Energy Suspension website is incorrect. I have a dana 60 front..Dodge switch to the AAM axles in 2003...w 3rd gen rams
rob
Old Apr 25, 2009 | 08:35 AM
CapnRam's Avatar
hmmmm...i just got my control arm bushings in yesterday, and i'm thinkin there the same part #'s your talking about, is there a way to check them before i tear into it?
Old Apr 25, 2009 | 02:56 PM
Yes, if you can, find a m14 size metric bolt and make sure it fits good into the larger metal sleeves that came with the kit, the stock bolt size on the lower control arms of the 99 and prior are m14, Im not sure what sizes the new ones are, I do know that they switched to the American Axle on our trucks in 2000, which is when I believe they also changed the bolt sizes, makes sense for the bolt size to change when the axles changed.
I literally just got back from our shop trying to install new control arm bushings im my 99, and the metal sleeves were too big, just Like Smokinrams so Im seriously ****** right now, these were prothane brand, says they fit Dodge Ram Trucks 2500, 4X4, 94-01 V10/Diesel, and they are not right, Im gonna return them and buy the 94-98 Energy bushings, anf if they dont fit, in gonna say to h--- with it and buy new control arms.
Old Apr 28, 2009 | 05:30 PM
DIESELWRKS's Avatar
confused. my 2002 has a dana 60 upfront. both my 2003 and 2004.5 they are the ones that had the AAM axles. any diff on 2wd to 4wd on the bushing size?
Old Apr 28, 2009 | 06:44 PM
Wicked500R's Avatar
Honestly... for the 240 bucks and no headaches except maybe having to get new bolts if your are rusted and break.... Top Gun Customs control arms with Skyjacker greasable bushings ... is the way to go... I think...
Old Apr 28, 2009 | 08:10 PM
I actually think your right, i was confused on the front end setup as the ball joint type and style as well as some of the types of steering linkages changed in 00 , but still used the dana axle. But I do think it was in 00 the larger control arm bolts were used, i looked under my boss' 01 and the bolts were significantly larger than mine, I ordered the 94-98 control arm bushings from Energy even tho I have a 99, the 99-02 will not work on my 99, its a misprint on the site, they should change it.
Old Apr 28, 2009 | 08:22 PM
RacerRon's Avatar
The front bolts are larger starting on 2000 year trucks.
smokinram99
Feb 22, 2009 11:22 AM
kawi600
May 23, 2006 12:26 PM
hamilton71801
Aug 18, 2005 03:14 PM
243
Aug 27, 2004 02:14 AM
