"Finger Touch" oil drain valve
Was thinking about installing one of these but I want to get some feed back on it before I bought it... Main reason I want it is so I can start taking a nice clean sample for analysis and close it off. I am worried about something somehow tripping the spring loaded lever without my knowing and putting me in a bad situation. Is this thing a bad idea?
fumoto valve is what I have, its lever operated and almost impossible for it to move on its own, you have to work against a spring to allow the lever to unlock. works great, one of the best mods I've done. I ran over a tire which smashed the front of my truck, even dented the oil pan...lever or valve never moved ( it never hit the valve)
here is a link with a pic, I got mine from larryb (starters) it was around 30$ if I remember correctly
I got one of those EZ change plugs that you have to screw the hose onto for it to start draining. Works like a charm, has a cap that ensures absolutely no leaks, doesn't hang down as far, and doesn't have a lever that 'might' get hit. I got my first from Geno's Garage, and second right from Cummins.
skindaddy
23
Jun 14, 2010 09:19 PM
rick83864
Mar 16, 2010 09:54 PM
Shovelhead
0
Jun 8, 2003 08:43 AM
