fast idle control ???
Old Jan 31, 2003 | 10:33 PM
dieselcrazy's Avatar
any1 make a product like this??? something u can set your throttle ....turn and lock it so it runs a little fatser idle on those cold days ??? ( used to drive an old mack onsite that had 1 was cool ) ;D any1 have any pics if there is such a thing ???
Old Feb 1, 2003 | 10:02 PM
Ray,IN's Avatar
Re:fast idle control ???
Pilot truck stops sell a cheap <$10, adjustable rod that fits between the go pedal and the undersideof the dash. I don't remember the brand though. I use one of the "turn to tighten" curtian rods my wife had laying around. I place it between the pedal and seat front and adjust to what's desired( usually 1,000-1200rpm). It works fine, as a diesel engine does not generate much heat on these -0* mornings at low idle.
Old Feb 4, 2003 | 11:00 AM
thatguy's Avatar
If you stop by a good size truck stop they more than likely have a &quot;throttle stick&quot; for sale.. I got mine for about $6... it works just fine and is a much cheaper alternative than cables/computer boxes etc..<br><br>good luck
Old Feb 4, 2003 | 11:54 AM
doodah's Avatar
JUST O SHORT BLOCK O WOOD BABY!!!! ;D ;D
Old Feb 4, 2003 | 05:01 PM
DieselDaze's Avatar
Check out the existing thread:<br><br>https://www.dieseltruckresource.com/...d=7910;start=0<br><br><br>Made mine out of PVC with one end notched in such a way as to prevent it from falling off the peddle.<br><br>Works great!<br><br>Rich
Jim Lane
Dec 7, 2015 09:16 PM
wmbthe4
May 8, 2011 12:19 PM
EdmontonCanada
37
Dec 9, 2009 03:18 AM
trik396
Mar 14, 2007 07:57 AM
