FASS ticking
Old Mar 4, 2008 | 12:15 AM
AKcruiserfreak's Avatar
FASS ticking
Hey all,
I have an increasingly irratating problem with my FASS HPFP. I installed a Drawstraw 2 with FASS at the same time, and the ticking began almost imediately. It's now so bad it sounds like speaker static whether idling or at WOT.
Where should I start? Should I deleat the pre-filter (NAPA cheapo) that FASS supplies in it's kit? Do you think the Drawstraw is pulling air? I just don't know where to begin.
Thanks for your help.
Old Mar 4, 2008 | 01:01 PM
Diesel-Dan's Avatar
Originally Posted by AKcruiserfreak
Hey all,
That pre-strainer is requiered for pump operation. It keeps debris that can jam the gears or pressure regulator up from causing issue.
Does the ticking have a frequency? Fast, slow? Does it sound like its coming from the motor....or the pump?
You can try to pull fuel from a bucket. That would eliminate the tank and draw straw.
The best thing is if you have a FASS dealer local you might swing by and let them listen to the pump. EDIT: I see you are in AK......UM...can you take a Vid of the pump?
1985cucv
Apr 11, 2010 10:42 AM
Buckshotmckee
May 23, 2005 12:08 AM
2wheelsup
May 17, 2005 10:45 PM
Flatty
Apr 25, 2005 12:49 PM
ralphie
Apr 21, 2005 12:51 PM
