FASS System Arrival
Old May 20, 2004 | 09:00 AM
rharveysr's Avatar
Talking FASS System Arrival
Well I finally broke down and ordered the FASS system for her 2000. And yes its a bunch of money but I decided that I would fix the lp before it goes out.
I opened the box last night and couldnt believe the massive size of the pump and filter head. And the quality of the rest of the kit was somethng else. I cant wait to get this system installed and see how the truck runs afterwards.
When we bought the truck it had -6n lines that the owner had replaced the stock banjos with. I decided to try a little experiment and replace the -6n lines with -8n line to see if there would be a noticeable difference...and yes there was.
I called and talked to Brad about the 3/8" feed line to find out whether or not it would be worth going with -8n lines. He said that with the hp of the truck now..I would not see a difference. With the information that I have found on this FASS system..I should notice a difference is how the truck acts. Fuel mileage may or may not change but with the way this system delivers the fuel..her truck should be much happier...
Rick
Old May 20, 2004 | 06:27 PM
graphitecumnz's Avatar
my truck loved the FASS....
Old May 20, 2004 | 08:44 PM
K2Cummins's Avatar
Mine too; one of my best purchases yet.
Old May 21, 2004 | 05:54 AM
Dieseldude4x4's Avatar
Mine three. Don't have any miles on it yet but it can't be worse that that stock garbage.
Old May 21, 2004 | 08:47 AM
rharveysr's Avatar
I talked to Brad yesterday about going from the 3/8" lines to 1/2" but I forget to ask the best route for the main feed fuel line up to the motor..
Any suggestions????
Thanks
Rick
Old May 21, 2004 | 01:01 PM
along the outside of the frame rail... there is an existing electrical bundle there; I used wire ties to secure it parallel to but not attached to this bundle... once you get to the engine compartment, just run it where it is unobstructed and won't get pinched or heated... I tied mine off to the existing hard line from the stock fuel filter...
Old May 21, 2004 | 01:47 PM
rharveysr's Avatar
I may end up getting some of that wire loom to cover the line so that it wont scrub..
Rick
Old May 21, 2004 | 02:44 PM
Timinva's Avatar
DTR Advertiser
I used hydralic hose covering over my1/2" line. You can get it at any hose shop. It is nylon braided and very tough. 20 feet of it was about $10 and it just slides over your hose. Tim
Old May 21, 2004 | 03:53 PM
MK4288's Avatar
how much did you end up paying for it total?? if you don;t mind me asking.
Gumby
Feb 17, 2016 07:30 AM
Hvytrkmech
Dec 17, 2009 06:23 AM
SD-Dave
15
May 15, 2007 02:29 PM
BCarmicle
13
Nov 7, 2005 04:20 PM
HighTen
Mar 8, 2004 12:33 PM
