fass problems
Old Apr 3, 2007 | 07:05 PM
99farmdodge's Avatar
fass problems
Just installed a new fass 150 gph fuel system on a 99'. I also have an edge juice w/ attitude and it only reads 2 psi. I cracked the 1,3,5 injectors and had fuel but the truck won't start and I keep getting air bleeding off of the return side of the pump. Is this a result of the low fuel pressure just isn't enough to finish bleeding the air. Just curious why I would only have 2 psi when the old stock lift pump had 12. Would appreciate any input, would like to have truck running asap.
Old Apr 3, 2007 | 07:12 PM
pmtg's Avatar
how much fuel do you have in the tank? all connections/fittings tight? any fuel leaks?
Old Apr 4, 2007 | 12:41 PM
Diesel-Dan's Avatar
Did you get the FASS to prime? Losen up just the fuel filter and leave the WS tight?
Ill write more after lunch....
I figured out that the fuel filter didn't get primed right even though I filled it full of fuel before I screwed it on. Loosened it a ran the pump, now I'm running 17 psi steady it doesn't fluctuate at all. It is nice to have it up and running again.
DJ Turbo.
Oct 13, 2011 09:11 PM
Buckshotmckee
16
Feb 14, 2006 12:32 PM
2wheelsup
May 17, 2005 10:45 PM
Flatty
Apr 25, 2005 12:49 PM
ralphie
Apr 21, 2005 12:51 PM
