fass or holly
Old Jul 9, 2005 | 02:30 PM
Barefoot88's Avatar
fass or holly
which is going to give you the best performance and easiest installation
Old Jul 9, 2005 | 02:37 PM
Haulin_in_Dixie's Avatar
Easiest installation, Holly. Best performance and only way to go, FASS.
Old Jul 9, 2005 | 02:40 PM
Barefoot88's Avatar
whats involed in installing the fass do you use the existing wiring harness or do you run new wires
Old Jul 9, 2005 | 02:54 PM
It should come with a harness.
Old Jul 9, 2005 | 03:19 PM
SuperDave4x4's Avatar
How much is a holley pump? Is there any where I could pick one up locally? I think I'm about to order Vulcans Lift Pump Relocation kit and a just use a holley pump since my lift pump is crappin out. Would that work well?
Old Jul 9, 2005 | 04:26 PM
shoe's Avatar
you can get the instructions for the fass install from one of the web sites not sure anyone else know?
Old Jul 9, 2005 | 04:59 PM
caleb c.'s Avatar
You can get a holley at Napa or O'Reilleys or whatever kind of auto parts store you have around.Should be around $130-140.
Old Jul 9, 2005 | 06:37 PM
graphitecumnz's Avatar
FASS or FASSII??
I have a FASS and for install you'll have to drill(or weld) the frame to attach the support bracket, run the fuel lines from the tank to the pump, from the pump to the injection pump, attach the return line and connect the supplied harness to the factory lift pump harness. It's about a 1.5 to 2 hr install if you're good in the shop.
Old Jul 10, 2005 | 01:20 AM
Kman9090's Avatar
Ive also decided to go FASS, im getting the system next week for 700$ installed.
Old Jul 10, 2005 | 03:54 AM
PourinDiesel's Avatar
FASS OWNS!!
Old Jul 10, 2005 | 12:37 PM
Barefoot88's Avatar
LOOKS LIKE FASS IS THE WAY TO GO LITTLE PRICEE BUT WORTH THE MONEY THANKS GUYS KILEY
Old Jul 10, 2005 | 01:01 PM
Well I dont have 500 bucks to blow on my rig, so I'm going with the Vulcan Relocation kit and a Holley Bule pump and its going to run me 240 bucks for everything! And a lifetime warranty on the pump which I'm sure I'll use. I'll let yall know how it goes I should be ordering everything on monday. If I could go FASS trust me I would in a hear beat.
Old Jul 10, 2005 | 09:07 PM
RickCJ's Avatar
I just got back from the Bloomsburg Truck Fest, they had a FASS demonstation, turn off you could see lots of foamy diesel flowing thru the lines and turn the FASS on and no more foam/bubbles in the fuel.
My truck definately runs better!!!
Old Jul 10, 2005 | 10:20 PM
slimchase's Avatar
I am very pleased will my FASS II, I have had it on for about 15k and It is still putting out the same pressure it did on day one. I think it was around $350 for all the stuff. It took about 2hrs to install.
Chase
Gear Poet
May 8, 2004 02:15 AM
Gear Poet
Apr 30, 2004 07:19 PM
Tengu
33
Apr 27, 2004 09:03 AM
