FASS fuel pressure ?
Old Apr 12, 2007 | 08:04 PM
Twodiesels's Avatar
Is there a way to check the fuel pressure manually at the pump. My fuel pressure used to idle at 17 and has now gone down to 16 at idle. Can the pressure be turned up? I can also drop it to 12psi at heavy throttle, where before it wouldnt go below 14psi.
Thanks
Old Apr 12, 2007 | 08:16 PM
Geico266's Avatar
Have you replaced your filter? Sounds like your guage is telling you something. I would not worry about 1 PSI.
Old Apr 12, 2007 | 08:35 PM
Twodiesels's Avatar
Yes both filters are new.
Old Apr 12, 2007 | 08:52 PM
smokindog's Avatar
Depending on the outside temperature I see about a 1psi variation.
I just swapped gauge styles yesterday though and I used to see 15psi on my old DiPricol, but now I only see 12psi on the new SW. It may be because I lost a little juice between the gauge and the isolator during the swap and didn't replace it, but even at 12psi I'm not worried.
rjm022
Jul 8, 2006 06:30 PM
MoparRiggan
Jan 5, 2006 11:09 AM
2wheelsup
May 17, 2005 10:45 PM
Flatty
Apr 25, 2005 12:49 PM
ralphie
Apr 21, 2005 12:51 PM
