FASS and FP gauge
FASS and FP gauge
I was wondering if it was better to use the port on the FASS to run the line for my FP gauge, or would it be better or more accurate to put a T in the supply line that is up near the VP-44 and run the line from there to the gauge?
Thanks
Thanks
Theoretically, there should be no difference in the pressure reading between the two locations. There will be a minute difference in the readings(probably not detectable without more precise equipment) due to friction losses in the supply line tubing.
I used it because it was easier and cheaper to connect....
I have a T fitting that will work in my box of misc. fittings out in my shop. I'm just going to run a line from the T to the isolator then use the supplied tubing to go from the isolator to the gauge. We'll see if it works.
ollie32
Jun 3, 2007 09:29 PM
rjm022
Jul 8, 2006 06:30 PM
Flatty
Apr 25, 2005 12:49 PM
