ez install question
ez install question
Just to start off, I’m still pretty new to the diesel world, so be patient…
I just bought a used edge EZ off a guy who had it in a 99. I’m trying to put it in my 2000. Can anybody tell me where I need to plug the 3 connectors in? The directions on the edge site don’t point it out very well.
Thanks for the help
Thanks for the help
If it will work at all, I think you will have to have a plug adapter. I'm sure someone will chime in with the info. In the meantime, you could check edgeproducts.com and see what info they have.
If you are refering to the triangle shaped data plug, it's near the front of the engine on the driver's side. About midway down. It will most likely have a dust cover you'll have to remove.
yeah, thats the one i have the question about. I found one with the cover, but on my 2000, its flat. the box i have has the triangle. I'm going to check with edge to see if i need an adaptor or something
I found the other 2 that you put in series (the MAP sensor i think).
spooled142
Mar 19, 2009 09:10 AM
AndyMan
May 11, 2007 07:50 AM
QWKRTNU
Sep 26, 2006 10:22 PM
MARKY MARK
Dec 23, 2002 02:02 PM
White02Sport
Oct 6, 2002 07:11 PM
