Driving light install question
Old Dec 16, 2002 | 08:03 PM
MARKY MARK's Avatar
I just bought some Hella rectangular driving lights. I will be getting the PIAA 510 fog lights for the round holes soon. Has anybody mounted rectangular lights in the bumper next to the stock lights? How should I mount them? I think I need to make a mounting bracket of some sort.
Old Dec 17, 2002 | 01:59 PM
MARKY MARK's Avatar
Re:Driving light install question
Has anybody done this? ???
Old Dec 17, 2002 | 05:14 PM
Thomas's Avatar
Like this?
Old Dec 17, 2002 | 06:52 PM
MCMLV's Avatar
...nice, 8) clean install. Which brand/model lights did you use? How is it switched?<br><br>Cheers,<br><br>Peter
Old Dec 17, 2002 | 07:14 PM
Thomas's Avatar
They're PIAA 60XT's—a good fit but not a particularly easy install. They are mounted to an aluminum channel that I positioned above the cutouts behind the bumper. The single bolt from the PIAA's goes through the channel. The difficulty part of the install was getting the lamps centered vertically in the bumper opening, slightly back from the front of the bumper, and aimed all at the same time. They were originally switched by a relay that was energized when the headlamps were on high beam.<br><br>I have recently installed the Sport headlamps and upgraded all headlamp/driving lamp wiring to relay switched 12 gauge wire. This takes a big load off the headlamp switch and allows the light filaments to burn a bit brighter. The driving lamps can be switched on or off, and are disabled when I dim my headlamps. All eight Sport headlamp filaments light when I switch to high beams. The foglamps can also be enabled with low or high beams. I went from the maximum 130 watts of front light power the truck had when built to a possible 705 watts of front light power with my modifications, all with standard output bulbs.
Old Dec 17, 2002 | 07:23 PM
MCMLV's Avatar
...thanks for the info.<br><br>Wow, with that amount of photons coming out of the front of your truck you could just push smaller cars out of your way .<br><br>I was thinking of doing HID upgrade for the headlights, but will see...
Old Dec 17, 2002 | 07:35 PM
MARKY MARK's Avatar
Thomas. That is exactly what I want to do. I have the Hella 450's. Guess I will have to wing it with the bracket. Thanks.
Old Dec 19, 2002 | 08:42 AM
DF5152's Avatar
i have a kit from PIAA to install light in both of these wholes if u r interested drop me a line maybe we can make a deal. it is unused i sold the truck before i could install the light. piaa used to make a light that was almost 9 inches long that would fill that whole perfect. I believe is is the same size as the 959 light but wasnt as costly a few of the truck shops around here still have several sets. i think they are about $200.00. <br><br>df5152@portjeff.net<br><br>http://www.portjeff.net/df5152/
Old Dec 23, 2002 | 02:02 PM
JoeDiesel's Avatar
Guys - here's an idea - go to your local Napa and check out the GE 4509 Par36 bulb - you'll find that there's a version of this aircraft landing light available which produces 110,000 candle power from 55W - combine this with a standard rubber PAR-36 housing and Viola! BRIGHT lights for few $$. Merry x-mas!<br> <br><br>
stratos201proxl
Jan 16, 2014 11:04 AM
Rollin'_Coal
13
Oct 8, 2013 03:28 PM
Joey-D
Dec 12, 2011 12:52 PM
KansasMan
Aug 25, 2004 08:30 AM
RATTLINRAM
Jan 19, 2003 08:23 PM
