EZ/Boost
Old Aug 10, 2005 | 02:12 PM
crobtex's Avatar
EZ/Boost
I got my third EZ back from Edge today and put it on. The response problem is solved and the smoke is now controllable.
I can still only get 22# of boost. My memory is not too good these days, but I seem to think I got closer to 30 # with the first box. I changed the boost elbow and can find no visible leaks in the inter-cooler lines.
What should my boost be with the EZ?
Old Aug 10, 2005 | 02:15 PM
Mcmopar's Avatar
I get 29-30 with mine.
Old Aug 10, 2005 | 02:17 PM
crobtex's Avatar
Where else do I look?
Old Aug 10, 2005 | 02:18 PM
Mcmopar's Avatar
For what?
Old Aug 10, 2005 | 02:24 PM
duallydave's Avatar
try another ez,even without the ez, wot you should see 18-20.or maybe your watgate is stuck open a bit.
Old Aug 10, 2005 | 02:30 PM
crobtex's Avatar
2nd EZ with the boost problem, and I do get 18-20 with the EZ removed. How do you check the wastegate?
Old Aug 10, 2005 | 02:41 PM
JDGnut's Avatar
Well.. I'm glad its gettng better.. You can take the line off the wastegate actuator, and use a little compressed air to make sure its moving.. but it could still be leaking inside... I sure didn't like the way that turbo looked... did you clean it?? and did it come back??
Bryan
Old Aug 10, 2005 | 03:08 PM
crobtex's Avatar
No, I haven't had a chance to clean it. I'll get some brake cleaner and getter done sometime this week. Can the cleaner be sprayed directly onto the blades and inside housing? How about Berrymans Chemtool spray? I know it will clean almost anything petroleum based, but I don't know if there is something inside the turbo that may get eat up by a strong solvent.
I still think the black stuff in the turbo came from the K&N I had in there for awhile.
Old Aug 10, 2005 | 03:25 PM
Mcmopar's Avatar
Do you have a picture? It could be the turbo impeller shaft seal??
Old Aug 10, 2005 | 03:43 PM
crobtex's Avatar
The impeller shaft and blades are tight, with no play at all. The black "stuff" on the blades is dry, not oily. Do you know if the brake or Berrymans cleaner will hurt the shaft seal?
I'll post a picture before and after I clean it.
Old Aug 10, 2005 | 04:00 PM
Mcmopar's Avatar
use carb cleaner, but blow it dry with air asap
Old Aug 10, 2005 | 04:13 PM
crobtex's Avatar
Gottcha. All I have to use is my heat gun on the low temp setting, but I'll give it a shot.
"pun intended"
Old Aug 11, 2005 | 12:25 AM
BigBlue's Avatar
With my waste gate clamped on mine and my comp in EZ mode before the injectors I could hit 29-30psi (I hit around 34-36psi with the injectors). I say you've got a boost leak or something. Maybe your gauge is faulty. If it's not working right by the next meeting I'll either swap gauges and see if that's it or swap injectors or something. This bothers me that your not getting what you should be getting. How's the power feel? If your getting around 20 psi without the EZ then that leads me to belive that nothings leaking. The next meeting I can make (it will have to be after august) we'll swap gauges if you haven't figured it out by then.
Old Aug 11, 2005 | 06:51 AM
crobtex's Avatar
Thanks for the idea Tyler. I never thought about the guage. I'll check it out today. Since it will pull about 20 without the EZ, I agree that it dosen't sound like a leak.
After I put the new box on yesterday, the power and response is back. If it is the gauge, it's on the top end since I can again feel the EZ kick in at about 10 psi.
Old Aug 15, 2005 | 08:51 AM
crobtex's Avatar
Well, I cleaned the turbo blades and around the inlet and can get it up to about 24/25 psi now. When I get a chance, I'll see if I can clean a little deeper into the turbo.
I had the camera with me, but my oldtimers blocked my memory and I forgot to use it.
HOHN
45
Oct 8, 2005 08:51 AM
triplenickel
Aug 23, 2005 04:01 PM
GTSDave
Jul 8, 2005 09:06 AM
MY WORLD
25
Dec 29, 2004 08:54 PM
Palmetto_kid
Jan 16, 2004 02:21 PM
