Exhaust system replacement
Old Dec 16, 2006 | 10:18 AM
Flyer's Avatar
Muffler split, turbo back looks stock. I found an alumized MBRP 4" turbo back at Extreme in NJ for $321 w/ free shipping.
Has anyone used this system?
Any tips for removing bolts from the turbo?
How does it sound?
Thanks for the help.
Old Dec 16, 2006 | 10:26 AM
MADMATT's Avatar
u taking ur turbo off?
Old Dec 16, 2006 | 10:33 AM
Flyer's Avatar
No, just the exhaust system.
Old Dec 16, 2006 | 10:37 AM
Rrloren's Avatar
I sprayed them with liquid wrench and used a long extension with a articulating knuckle on it from underneath. Also had use of a lift , which really helped.
Good luck.
Old Dec 16, 2006 | 12:21 PM
clarson80's Avatar
I couldn't get those two bolts to break loose when I put my MBRP system on. I ended up taking the clamp off between the turbo and elbow right before the downpipe. Then it's easy to take the bolts off the downpipe after they are out from under the truck. If you do that, soak the nut on that clamp with liquid wrench for a while, it looked like it would be pretty easy to break it.
Old Dec 20, 2006 | 12:15 PM
Flyer's Avatar
Got the system in last night. Bolts on turbo came off with Liquid Wrench. Took a bit to get the new ones on with the 4" not having the same clearance as the 3.5". Truck sounds good.
Thanks for the advice.
RiverRat2
Oct 15, 2019 10:59 AM
superdodge
Jan 30, 2010 07:16 PM
JSPulliam21
43
May 26, 2008 10:38 AM
coastal_diesel
Mar 12, 2005 12:21 AM
chucktownsend5
Feb 25, 2005 02:31 PM
