Exhaust brake
Most exhaust brakes generate about 180~190 brake horsepower at ~3,500 rpms. If the torque convertor isn't already slipping under towing loads, then it will handle an exhaust brake. However, there are thrust washers in the automatic prior to 2004 or 5 that were not designed to handle the reverse thrust generated by the EB. To be safe, you should check into trans upgrades.
coalburner400
Aug 1, 2006 06:37 PM
2500TurboDodge
Jun 28, 2005 09:52 PM
