Engine misses after hard run?
Old Apr 12, 2007 | 10:18 PM
srt20's Avatar
My truck will occasionally miss or spit and sputter after a hard run. Once Im stopped, just a little blimp of the throttle will clear it up. Anyone know what causes this? Thanks Bret
Old Apr 12, 2007 | 10:29 PM
ncdodgeman20's Avatar
hey man i really dont know what causes the miss but when i install my comp box after a hard 5x5 run it seem to miss some also but i really couldnt tell what causes it also if you dont mind i was wanting to know how you like your set with jwa and the smarty and stick i would like to have some detells aslo are you runing this with the stock turbo???thanx mike
Old Apr 12, 2007 | 11:07 PM
Tiger Rag's Avatar
It usually happens with a hard fueling box like the TST comp. My regular TST on 9 at the drag strip will do it a little. My guess is that on a hard run you have pretty much drained the VP and it is spitting trying to catch up....ie, no fuel to inject in to the cylinders.
Old Apr 13, 2007 | 07:55 AM
hamilton71801's Avatar
My injectors will cause mine to lope some after a hard run sometimes. Like you said, a little tap on the throttle usually clears it up.
Old Apr 13, 2007 | 08:14 AM
getblown5.9's Avatar
alot of vp44 guys have this problem when running injectors and comp or TST box. just when you run WOT hard like that then let off, the pump just kind of gets hiccup if you wanna call it that, takes a second to straighten back out
Old Apr 13, 2007 | 08:28 AM
dzlfarmboy's Avatar
Yeah i've never really noticed mine sputtering much but i have air locked the injection lines before after a long hard run and let off instantly,truck just cut out and wouldn't start. Had to crack some injector lines to get it started
Old Apr 13, 2007 | 09:17 AM
met a guy with a 6 spd who air locked his lines every single time he let off and pushed the clutch in, but he could get it running again by putting it in gear and letting the clutch out while he was still rolling.
i've always had to crack the lines and bleed them
Old Apr 13, 2007 | 04:36 PM
ct2500's Avatar
mine will run funny after a long hard pull on 5x5 tap throttle once and it is good.
Old Apr 13, 2007 | 04:44 PM
CL2000's Avatar
Vp just cant keep up and mixes a little air between the pump and lines.
Old Apr 13, 2007 | 05:21 PM
99globalwarmer's Avatar
ya same here it just happened i got my mach 6 in and wow, it lopes after a hard run.
Old Apr 13, 2007 | 07:27 PM
74dart's Avatar
When I put in my 370s two weeks ago I bleed the lines without cracking them.
Old Apr 14, 2007 | 11:48 AM
srt20's Avatar
Yes I have the stock turbo. I havent towed a thing with this setup yet. Im sure the Juice will have to be turned off or at least way down to tow. I like this setup alot. Makes the truck very quick!! But it will get hot in a hurry. I have the defueling enabled so I dont burn it down. If Im going 55mph and floor it on 3x5 it will hit *1500 in about 3-5 seconds. But thats still long enough to let someone know that they aint gonna outrun me......lol
Stroked-Z
Oct 4, 2008 11:28 AM
JD farmboy
Jun 19, 2007 11:40 PM
smiffy
May 16, 2004 10:18 AM
KansasMan
Dec 10, 2003 01:07 PM
routerguy99
19
Sep 23, 2003 06:37 AM
