Engine behavior with large injectors and an EZ
I have a 01 HO 6 spd. With stage 4 EDM injectors, a TST PM3 Competition version stacked with an EZ. This has bothered me for some time.... when on the highway and I use from about 1/4 to 1/2 throttle, the engine surges and bucks quite badly. enough to bounce you in the seat. Under 1/4 throttle, perfectly smooth, over 3/4 throttle perfectly smooth.. So for some experimentation, with the PM3 on 0 it still does it. So I took the edge off and left the PM3 on and its perfect. I am surmizing that the advanced timing created by the larger injectors coupled with the additional timing from the EZ is causing this surge. But I cant STAND my truck without the EZ stacked. It adds gobs of bottom end that I cant live without.... What about the jumpers in the EZ. I have mine on the quickest rate settting (most smoke too) Does anyone know what exactly the jumpers do to the timing and/or fuel curve?? I am gonna try the middle jumper tomorrow and see if it still does it...
Anyone else notice this same condition with their rig??
Kevin
Kevin
Mine does the same thing and i just run an EZ with a set of DD2's.
It is especially noticeable in 6th gear when you just put your foot into to pass someone. It bucks and a little shudder and away it goes.
I oringinally thought it was spring wrap up because that is kind of what it feels like but it only does it in the upper end of 4, 5, 6th gear.
I am not liking it but just kind of ignore it. Not sure how to fix it.
I only notice it if the engine is under 1500 rpm when I get on it. Only cure I've found is to downshift and keep the revs up to get 'er lit, then after the upshift it seems a bunch smoother.
I believe what you're seeing is the Edge starts it's different fueling map around 10psi of boost. At least this is what happens on the drag comp. If I cruise at less than 10% throttle and keep the boost at 10psi, I get the same bucking that you're describing. Changing the jumpers should move the point the map changes either up or down, effectively removing the bucking from your daily driving routine. I'm a little surprised you didn't see this with your PM3 comp on higher levels? The TST box was unusable as a daily driver on my truck, I couldn't run it on any level without it shuttering at anything less than WOT.
brandon.
brandon.
Yup, it sounds like you guys have the exact same problem.. Except maybe Beast2B... mine will do it at any RPM even up at 2,400.. Its only a function of throttle position, and maybe as Brandon says a particular boost pressure too... I will monitor the boost pressure closely tomorrow and see if it does it allways around the same boost...
And it is in fact worse with the PM3 on higher levels, but I think that it is amplifying the condition not creating it since it will still do it with the PM off and just the edge....
I am not terribly happy with the PM3 either, but not cause of bucking.. I think its a dog down low... What did you switch to Brandon??
Tryin the middle jumper tomorrow.
Thanks guys
KP
Thanks guys
KP
Kevin, The jumpers wont do squat believe me. when we dyno tested the ez in different pin setting there was litltle to no change.
How about testing a Catcher in place of the EZ?
yes? no? maybe?
I bet you will like it
let's talk
yes? no? maybe?
let's talk
I switched to a drag comp & love it. I can run daily on 5x5 with Mach6s if I watch my right foot during low boost. It gives the low end push when it's on. I'd like to test the MadECM, but can't justify the cost since I already have the drag comp. I don't think it would give any additional power over the superchips/drag comp stack.
brandon.
Middle Jumper this morning on the way to the power station.... same thing only now I have less bottom end on initial application of pedal and I cant smoke out the tailgaiting yuppies as bad...
Cool Brandon, I was thinking about the drag comp. But what I think I will really do is get rid of the EZ and get a MAD ecm. That and the fueling only TST PM3 might be a good setup...
Yup, Bob that is exactly what I was thinking and have been thinking for a long long time....
I have heard just tons of great stuff about the MAD and rode in a MAD truck once... Its really nothing like anything else out there... Think its time to step it up.. BUt I am concerned because I think its the timing of the EZ thats giving me this surge/buck and I know the MAD has a bit of timing. I would like to test it first before shelling out the cash if that is possible??? I will PM you....
Kevin
Kevin
This is funny to me...I have asked a few times about the negative effects of larger injectors with daily driving and I never get replies like these. I only hear how GREAT they are. I really want them but I'm having a hard time weighing the pro's and con's.
brandon.
Originally posted by joefarmer
Huh? Daily driving with the boxes turned off and large injectors is a pleasure! The problems with the PM3 stem from running it on the upper race-only levels and expecting it to behave nice. There's nothing wrong with larger injectors on the street if you have correct turbo setup. For instance, I've run Mach 6's daily for over a year now. The Drag Comp stays on 2x1 unless it's time to kill ponies and cute little bowties. It's been one long, continuous smile.
brandon.
brandon.
Katoom
I dont know how large you meen but as for my Jammer IIs the only negative thing I can say about them is a little low boost smoke(If smoke bothers you) Maybe thats because there not that big?There is absolutly no drivability quirks or issuses I have found. I hope I can say the same after I step up this summer.
katoom, I can tell you that it only became a problem when I stacked the EZ with the PM3. Then I figured out that even with the PM3 off it still did it. But without the EZ it is perfectly smoothe. With the PM3 even on 9 it is like glass. So it seems to be some combination of the EZ and the injectors on my truck. It is also strange to find out that lots of other guys dont have this problem.... It might be injection pump related too, as I think mine is dying for sure... But to get just injectors or injectors and a PM3 I would say there are in fact ZERO negative aspects of that.. its just perfect and you will love em.
Kevin
Kevin
