EGT Temps
Old Mar 25, 2010 | 06:02 PM
diggerfan99's Avatar
EGT Temps
I was wondering, how much will a 4inch exhaust lower the EGTs? I can hit 1100F with no load. Thats stabbing the throttle pretty good, and Edge J/A is on 3x2. Seems high without a load, haven't had this J/a long enough to know whats high and low.
Old Mar 25, 2010 | 06:53 PM
Tate's Avatar
For short bursts, high egt's aren't all that bad. I've pegged my pyro many times with no ill effects. Its sustanined temps you need to worry about.
Old Mar 25, 2010 | 09:37 PM
busa's Avatar
1100 is no big deal, you could probably keep it at 1100 with a load for a while with no issues. When towing I back off at 1150-1200. A 4" exhaust will help a bit but not very much.
Old Mar 26, 2010 | 10:31 AM
rebal's Avatar
maybe 50*. 3" is good for 400 hp but 4" sounds cooler
Old Mar 26, 2010 | 11:26 AM
Lil Dog's Avatar
True.. a 4" system does help but not as much as upgrading the turbo. For your power level the stock system isn't bad.
Old Mar 26, 2010 | 01:16 PM
high bid's Avatar
5" dropped my EGTs close to 200*. I tow and wanted to drop EGTs as much as possible thus the reason for 5" exhaust.
Old Mar 26, 2010 | 01:23 PM
CODODGE2500MAN's Avatar
Straightpiping it dropped mine a little too....
Ie. I'd do a 4" straightpipe.
Old Mar 26, 2010 | 01:29 PM
bludodge21111's Avatar
i have the juice w/attitude and with my exhaust i never see above 1200 on level 5. Make sure if u do it get the 4" downpipe that really help the truck breath. Ive had great results with mine. Good luck
Old Mar 26, 2010 | 06:38 PM
Cool, I just wanted to make sure I was running about normal. Now the only thing I can't decide on is Out the Rear or do I want Stacks? Anyone with advice?
Old Mar 26, 2010 | 06:57 PM
busa's Avatar
Don't do stacks if you tow, very loud and covers everything with soot
Old Mar 26, 2010 | 09:54 PM
rebal's Avatar
Ya if you tow stacks will make your eye ***** rattle its cool at first but it will get old real soon
Old Mar 27, 2010 | 08:59 AM
high bid's Avatar
and then you have some really big drain holes in your bed for cleaning.
Old Mar 27, 2010 | 02:50 PM
DragonSlayer's Avatar
No stacks, just run it out like normal.
Old Mar 28, 2010 | 09:45 AM
sheriffav8r's Avatar
From what I've read stacks are cool at first but then get old real quick....
northern puffer
Dec 23, 2003 09:00 PM
8secondride
Mar 9, 2003 09:27 PM
8secondride
Mar 1, 2003 11:21 PM
