egr
Old Jun 25, 2007 | 10:45 PM
curts99's Avatar
egr block off kit?
are there any companies who make an egr block off kit for a 97 12v also a moderate fuel plate?
Old Jun 25, 2007 | 11:23 PM
curts99's Avatar
anybody know of a companie that makes a block off kit, also im thinkin bout an 11 or 12 plate for this guy he tows a horse trailer quite abit and is a 5 speed truck 2wd
Old Jun 25, 2007 | 11:32 PM
wcbcruzer's Avatar
I don't think you can remove the EGR. But you can still add a fuel plate. www.tstproducts.com. Or you can grind your own fuel plate with the templates available floating around on this forum.
Old Jun 25, 2007 | 11:35 PM
curts99's Avatar
there has got to be a way to remove it and fool the computer to make the check engine light not come on
Old Jun 25, 2007 | 11:36 PM
wcbcruzer's Avatar
Not that I've heard of... unfortunately... You're probably right, there must be a way. However, the percentage of EGR trucks are so low that nobody has really put much research into it.
Old Jun 25, 2007 | 11:38 PM
curts99's Avatar
true ill have to do some reasearch and maybe make some calls
Old Jun 26, 2007 | 12:37 AM
Ph4tty's Avatar
I believe disabling a smog device is illegal thus it would be against forum rules to advise you on this matter
Know a good with a welder?
Old Jun 26, 2007 | 09:20 AM
Danavilla's Avatar
I installed "test"plates on both ends of the EGR tube on my '98 and used a method of fooling the PCM about what I had done. It involved using a relay and resistors to convince the PCM that the IAT was seeing a increase in temperature when it commanded the EGR valve to open. I've since sold the '98 and my computer with the schematics has crashed so I don't have them any more. Since tampering wih smog stuff is illegal, details on here probably aren't appropriate anyway .
Dan
Old Jun 26, 2007 | 07:39 PM
curts99's Avatar
all of our programes downladers etc. are not smog leagel technically tampering with any of the emmissions on any vehicle is illegal, exhaust, larger turbos, changing injectors, etc is illegal how ever if you have a c.a.r.b sticker or if its a.r.b approved it is ok and to get super technical you cannot even modify the vehicles suspention or puting after marked rims on a vehicle is illegal if someone wanted to get really crappy with you but hey its all part of making th personality of your vehicle (correct me if im wrong)
Old Jun 27, 2007 | 12:51 AM
Ph4tty's Avatar
I could care less really, just trying to save the admins from having to use their stick Couldn't you just retrofit parts from a non CA model?
Old Jun 28, 2007 | 11:18 PM
curts99's Avatar
its the fooling the computer part that i dont want to take the time with and figure out how to do it so if someone had the info or there was a kit that would be easier. just bein lazy i guess ill have to do some playing
Old Jun 29, 2007 | 12:16 AM
Danavilla's Avatar
PM me w/ your e-mail address or e-mail me at Danbavilla@wmconnect.com
I'll see if I can pull some info together.
Dan
MOJO1
Aug 4, 2009 06:28 PM
nwilliams98
Apr 19, 2003 10:45 AM
commtrd
Mar 23, 2003 05:44 PM
spitzair
Dec 11, 2002 09:08 AM
