EDM / Mach 3's & towing
Not yet.
Yep ... was a little worried, all the talk of 3s being un-towable & all. Even did some 30+ psi running ... the PSD challenged.
The PSD driver had a
as he was being left behind. That's a 1st.
EGT was down there. 30psi & under 1200 degress. The upper 30psi run didn't get to 1400. Thats @ 4500 to 5300' elevation & temps mid 80s to lower 90s.
Ran with the Valet switch in the low power / no rack travel mode on the way home today. Plenty power for most applications.
as he was being left behind. That's a 1st. EGT was down there. 30psi & under 1200 degress. The upper 30psi run didn't get to 1400. Thats @ 4500 to 5300' elevation & temps mid 80s to lower 90s.
CTD_Neil
Nov 1, 2005 09:47 PM
sway825
Dec 8, 2004 10:21 PM
HOHN
36
Jan 22, 2004 11:14 AM
