EDM injectors
Old Dec 23, 2003 | 06:32 AM
yrusoslow2's Avatar
EDM injectors
I was just wondering where to get some edm injectors and about how much they cost. This is not for my truck it is for a 2001 HO.
Thanks
Justin
Old Dec 23, 2003 | 07:54 AM
hellotbone's Avatar
Re:EDM injectors
Don M formula one diesel http://mysite.verizon.net/res06gkt/page1.html
Old Dec 23, 2003 | 09:10 AM
Cummins4Life's Avatar
Re:EDM injectors
Rip Rook http://www.sourceautomotive.biz is where I got my mach 3's. ;D
Old Dec 23, 2003 | 09:22 AM
gandrews's Avatar
Re:EDM injectors
I got my EDM2s from Rod at http://www.wildcatdiesel.com/
They seem to work really well. A whole lot more grunt at low end than the RV275s and no smoke with the box off - but some at the higher levels.
I think you will like them ;D
Old Dec 23, 2003 | 10:41 AM
Idaho CTD's Avatar
Re:EDM injectors
I just recently swapped the BD3's in my 5spd for a set of Mach 2.5's. Initial road tests have been pretty impressive. The egt's are quite similar to the BD3's but the smoke level is closer to the DD2's I use to run. Even running on 3-3 with my edge comp I cant get these things to smoke as much as my BD3's with the box off. Man I miss my smoke :'(
Old Dec 23, 2003 | 02:13 PM
smittybuilt's Avatar
Re:EDM injectors
anybody running the mach 4's? i've got a set that just came in and i also got my B1 in today. hope to have them both in before the new year. just wondering on smoke issues. everything i have seen posted have been 2's or 3's.
Old Dec 24, 2003 | 10:36 PM
Timinva's Avatar
DTR Advertiser
I ran the mach4s for a couple months, mine were the older style than the latest ones though. Smooth idle and lots of power. Switched over from dd3s and they made 60hp more. They had quite a bit of smoke off boost but the newer style are a lot cleaner, my new mach5s smoke less than the older mach4s. Tim
hellotbone
33
May 22, 2004 01:34 PM
bwat4
Dec 23, 2003 04:14 PM
pro puller
13
Apr 18, 2003 09:39 PM
hellotbone
19
Mar 7, 2003 02:01 PM
KatDiesel
69
Feb 23, 2003 08:01 PM
