Edge Juice with Attitude!!! help!!!
Old Oct 20, 2006 | 10:34 PM
DISTURBED's Avatar
So lately while I'm drivin dowm the road i've noticed my moniter will freeze up when it decides to actually work but most off the time when i turn my truck on the back light on the moniter will turn on and everything but all the digital gauges read 0? and also when i turn the chip up to level 5 it will turn up cause i can feel the difference but the moniter will still read at the stock level? so i called edge and they said it was a bad monitor so i ran out to edge and got a new one no problem!!! but i still have the same problem and all my connections and they are all good so i dont know what the deal is??? any help would be great thanks
Old Oct 21, 2006 | 09:08 AM
97crewcab's Avatar
It wouldn't hurt to check your connections but I would get another monitor from edge.
My buddy went through 5 on his 03 before he got one that worked and since has had no issues.
Old Oct 21, 2006 | 01:19 PM
scottsjeeprolet's Avatar
If you are lucky enough to run out to Edge, get them to look at it while you are there, or if they won't put the new one in on their parking lot and if it don't work keep going inside and getting a new one til they get fed up and come out and look at the truck themselves.
Old Oct 21, 2006 | 08:03 PM
DISTURBED's Avatar
so its most likely the moniter then? it wouldn't be the juice box?
Old Oct 21, 2006 | 09:43 PM
Sea01Cummer's Avatar
Mine does the same thing but only in the summer when i let it idle for a while and it gets hot under the hood. I have to stop and pull the power wire under the hood , then all is good. That reminds me i need to get that taken care of before warranty exspires.
Steve
Old Oct 22, 2006 | 07:49 PM
roberts11260's Avatar
juice
when i was installing my edge juice with attitude I was a bit supprised to see they mount the box in the engine compartment.
I thought fursure they would have made the wires long enough so the box would be inside the cab away from heat.
I just put on the juice and love it, although the clutch is starting to slip on level 5.
I still think edge makes a great product
zdodge3
14
Sep 8, 2007 11:04 PM
RockcrawlingTJ
Nov 6, 2006 10:43 PM
CTDPower11
Jul 30, 2006 04:47 AM
DixieMfg
Jun 1, 2006 09:50 PM
razor6
22
Jan 20, 2006 03:43 PM
