Edge J/A "weak"
Old Oct 7, 2008 | 10:03 PM
016spd's Avatar
Edge J/A "weak"
I have a J/A with the wire tapped. Went on a long trip this weekend, mostly towing 8-10,000 lbs. Had it on level 2 most of the time. Pulled very well. Got home, unhooked, and tried it on level 4 just to see what is was like again. Did not have anything like it used to. Before this trip, on 4 it could put you in your seat. Now it hardly smokes when you punch it. Any thoughts on this? Anything wrong? Also on a long hill, fp would pull down to 6 psi, cruising it would be 8-10. Do I need to start looking for a better lift pump to save my vp44?
Old Oct 7, 2008 | 10:06 PM
EBunger's Avatar
Vp ran with that low of pressure regularly tells me Vp probably on its way out. Mine started showing lower EGTs and also long cranks to start before it went.
Old Oct 7, 2008 | 10:08 PM
Flatbed24v's Avatar
no ideas on the j/a but yes to the Lp, sounds like your Lp is about to go out just my two cents
Old Oct 7, 2008 | 10:18 PM
016spd's Avatar
i also only pulled 26 lbs of boost. I dont know, but it could've used more. Anything I can do for that?
Ludwig,09,6.7
Jul 2, 2011 01:06 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
joeinblueout4u
Feb 28, 2006 08:46 PM
lightening ram
Jan 4, 2005 10:45 PM
mopar2ya
Aug 26, 2004 12:23 AM
