Edge EZ adjustment??
Old May 31, 2007 | 10:01 AM
89dieselkong's Avatar
I keep reading that the Edge EZ comes with 3 or so adjustable power levels. All I see is the box. Where are they located??
Old May 31, 2007 | 11:03 AM
Barry St John's Avatar
Take the cover off the end of the box. There is a jumper that can be moved for the different settings. I don't remember exactly what they were so you will need to read your literature but I built an extended cover for mine with a couple of switches. It was more work than it was worth. Good Luck
Old May 31, 2007 | 11:23 AM
RowJ's Avatar
Here you go.... Had it saved from way back when.
EZ Settings / Fueling Percentages
Setting #1 = 33% of additional fueling @ 0 psi…….100% @ 20 psi
Setting #2 = 50% of additional fueling @ 0 psi…….100% @ 15 psi
Setting #3 = 67% of additional fueling @ 0 psi…….100% @ 10 psi
I think far left is #3 but don't exactly remember. You'll be able to tell difference in #1 and #3 by the smoke.
RJ
Old May 31, 2007 | 06:23 PM
Thanks guys...
Old May 31, 2007 | 06:38 PM
crobtex's Avatar
Depends if the circuit board is in the top of the case or the bottom. The "top" being the side of the case with tho logo on it. I'v had two different EZ's, and one was in the case opposite the other one.
rjm022
Nov 16, 2006 01:13 PM
Brohlfs
17
Nov 18, 2004 05:55 PM
Hoss
13
Jun 18, 2004 06:14 PM
powerwagon440
Jan 20, 2003 08:50 PM
