Edge comp wire tap?
Old Mar 15, 2010 | 11:46 AM
Hothead2500's Avatar
Edge comp wire tap?
What if you don't tap the fuel inj. Pump? What will happen?
Old Mar 15, 2010 | 12:48 PM
madhat's Avatar
Administrator/Jarhead
You will not get the added power. From what I understand (my experience on 2nd gen's with an Edge Juice with attitude) it's only like having power levels 1-3.
Old Mar 15, 2010 | 01:31 PM
macjazzy's Avatar
Correct, if you don't tap the wire you will only get level 1-3. I did tap mine, although it was on a newly replaced VP44 and I immediately upgraded my fuel system. It has been fine for approx 60k miles now.
To be honest though I drive probably 95% of the time on level 2. So depending on what you are using it for, you may never even miss the other 2 levels.
Old Mar 25, 2010 | 02:02 PM
jrv15's Avatar
yeah i took the plung and tapped my new vp44. screw the warranty. i have a edge juice. i pretty much drive in level 3. unless i wanna smoke someone!!!
Old Mar 26, 2010 | 09:16 AM
Redliner's Avatar
If you dont tap it it is the same as an EZ box. About 60-65 hp.
LovinTheTorque
Sep 14, 2013 12:02 PM
glarior
May 17, 2011 07:46 PM
Hoss
Apr 11, 2006 11:37 PM
raybob_99
Mar 30, 2006 09:51 AM
HiJenks
27
Oct 10, 2005 08:09 PM
