ebay headlght review
I purchased the ebay headlights for my 98. I got the 94+ ones projector. They shipped and then I recieved them the next day.
I put them in, no wiring yet for the little lights, just plug em in....Everything smooth. The high beam light on the dash stays on though....any input on that?
As for the lights.....THEY ROCK, I still need to adjust them, but they are unbelievable compared to the oem headlights. I think they are dimmer when the hi's are on....and I have to wire the small lights and figure out why the hi beam indicator is on either way, hi or low.
But the lights are incredible, I think its the first time I ve ever seen anything after the sun set. think maybe the relay mod and its done....just incredible compared to the bic lighter oem setup.
Don't cut the wires!!!!
All you need to do is change the highbeam and ground wires in the plug on the head light. You have the two wires together(that is the ground) and then you need to check with a meter to find out which wire is for highbeam. On the plug on the truck side I beleave the high beam is in the center. This is the exact problem I had with my lights from ebay.
Did you get the option racing ones? I put mine in last week and was disappointed with the light pattern but after a few nights of tweaking the adjustment I finally have bright lights. I already had the hi/low conversion for the old headlights and so that's just icing on the cake.
Sea:\>Drive
31
Dec 18, 2012 07:29 PM
04ctd
Dec 16, 2008 02:20 PM
USMC64-70
Dec 23, 2004 08:27 AM
TPilaske
Nov 19, 2002 02:00 AM
