Dynoed with the Mach 4's
I ran my truck on a dynojet today at a local dyno day. I have only had the Mach 4's in my truck for a couple of months and I havent really done much tuning with them but I still put down some good numbers.
My first dyno pull I set the TST to 3 and ran it just on fuel and it put down 510 hp & 955 tq
The next two pulls I turned the tst up to 9 and turned on the nitrous and it made 680 hp & 1195 tq
Well to say the least I was pretty satisfied with the numbers. My goals were to break 500 on fuel and 600 on nitrous with the mach 4's.
i just recently dynoed my truck on mach 4's only i put 324(thats with the ps 62/14). my drag comp wasnt working at that time. jan 5 i will be going back now that i got my comp working and see what the final numbers will be.
that would be over 170 hp to the wheels with just the tst. am i seeing this correct?
Back in the day, I had mach 6's sps62 smarty/tstmp3comp with some HOT W/M injections and just made 530 HP, But mine was on a HO truck, that's not supost to make as much as a SO truck. Moules it sounds like you pump might be weak, you should have be closer to 400+ with just mach 4's 275 stock+ 150 sticks=425ish and with the air to suport it.
actually i believe our trucks stock will dyno somewhere around 190rwhp. my injection pump is a SO and is 4 months old. this is why i am trying to figure out if adding a tst would get me to 500rwhp. atleast thats the impression im getting from reading this thread.
my truck with mach 4's and a PS62/14 put down 324.
am i not understanding these configurations? please correct me if im wrong on something.
so do u think the drag comp with my set up will actually give me more than 120 hp?
rockjeep and fellows i appreciate the info. my goal as of right now is to be over 500rwhp without spending much more money.
thats what i meant
It depends on if the malfunctioning Drag Comp was still boost fooling. If it wasn't, then the M4-only numbers are way low, and that's why you're seeing 170 as the TST difference.
Honestly, I'm almost POSITIVE that the Drag Comp wasn't boost fooling. M4s alone with a boost fooler should show you over 350hp at the wheels. With an EZ and M4s, you should be right at 400hp.
TST/M4s should be over 500 on an SO pump, and within spitting distance on an HO pump.
justin
justin
