driving lights that fit in factory locaiton?
Old Aug 2, 2005 | 12:07 AM
Patrick Campbell's Avatar
Can anyone recommend any PIAAs, KC's, Hella's or other common brand that will relatively easily fit in the stock non-sport truck location?
Old Aug 2, 2005 | 07:13 AM
2500CTD's Avatar
Daniel Stern recommended a set of Bosch lights that are my list of add ons. He says they fit very nice. I haven't seen them in person, but he seems to know a thing or two about lights.
Old Aug 2, 2005 | 11:50 AM
signature600's Avatar
PIAA 510 Series are supposed to fit in the factory spots with the right brackets...PIAA Part number 30195.
I'm gonna try them sometime when I ever get around to it!
Good Luck,
Chris
Old Aug 2, 2005 | 11:56 AM
ouch 510's are expensive... $85 per lamp.
Old Aug 2, 2005 | 07:16 PM
caper's Avatar
I got the piaa 510s with custom mounting brackets I made (check pics) . Yes they cost me $330 CDN but they are worth it , you wouldn't believe the light they thow. I have them wired to come on with my brights. I have a sport not sure if the hole is the same size or place on a non sport.
Old Aug 3, 2005 | 12:50 AM
ArcticWolf's Avatar
Remember to check to see which front bumper piece you have where the factory fog lights go - there's 2 different ones (I found this out the hard way)..
If your truck came with NO lights, then the holes will be much smaller - if you want to use them some cutting with a saws-all will be needed (and praying that you cut them the same! LOL), or you can either go to the dealer or junkyard and get the ones for foglights (the holes are much bigger than the non-holed ones) and simply replace them.
Old Aug 3, 2005 | 11:47 AM
2500CTD's Avatar
This just make me remember why I had that 4" hole saw!! My Dakota, fefore the Ram, had no foglights, and that meant no hole in the front bumper cover, one hole saw coming up!!........... My ram doesn't have foglights either, and I haven't decided on how to get them in there. Like said above, I'll prolly get the correct one for foglights.
Old Aug 13, 2005 | 03:48 PM
eric13's Avatar
You can usually find the whole kit,brackets, bumper peices, lights and new headlight switch made for foglights for about $175 on ebay just like factory
Old Aug 13, 2005 | 06:38 PM
JAF's Avatar
JAF
I used 4" spot lamps from an agriculture supply store. Incredibly easy and $32 was a lot better than $180 each from Dodge to rep[lace my broken ones.
J Lent
Feb 25, 2009 10:06 PM
tntshrekuk
Jun 25, 2008 12:02 PM
msatow
Sep 27, 2006 07:32 PM
CHarlan
Aug 6, 2003 08:40 PM
