drive pressure test
drive pressure test
hooked up an old oil pressure gauge to the manifold last night. it was kind of hard to read cuz it was bouncing all over the place under load. at wot, seeing about 33-34psi boost, i was seeing 75 psi on the other gauge. and my exhaust housing is very heavily ported.
i'm not sure what to think.
I have become a big believer in backpressure robbing power from our motors. Not only does it rob HP it also is hard on all the internal parts, headgaskets, turbos, etc. If you install a larger exhaust housing and wastegate it around 30 psi you should see a performance gain plus egt reduction.
Doug
Doug
Bart
What do you get above 45 psi boost. I'm interested in the comparisons between B-1's and the HTB2.
I also get 1:1 TIP (drive pressure) at 45 psi. At 51 psi boost (my max boost) I jump to 65 psi TIP.
What other bombs??
RJ
What other bombs??
RJ
Originally posted by swank
Your pressure guage needs to be snubbed.
what do you mean by that?
If you are exceeding the rating of your valve springs, usually 60 lbs, back pressure any higher will cause damage. Highest back pressures I've seen are on stock trucks with an exhaust brake on with zero boost, about 45 psi. All the modified ones I've checked are lower due to no or free flowing mufflers and larger exhaust pipes.
chuck3
Oct 15, 2002 01:17 PM
