drive pressure
Old Dec 9, 2008 | 05:41 PM
Flatbed24v's Avatar
drive pressure
how does one go about to check this? Is it easy, simple hand tools or do I need special tools?
Old Dec 9, 2008 | 06:02 PM
kantdrive55's Avatar
DTR Advertiser
Drive pressure traditionally on a single turbo isnt really that important. All it is is the pressure coming out of your exhaust manifold. So if you tapped the exhaust manifold and ran it to a pressure gauge that would be your drive pressure. It is a little more complex than that, but that is it in a nutshell. Like I said drive pressure really only matters on a twin turbo setup.
Old Dec 9, 2008 | 09:45 PM
Flatbed24v's Avatar
so when I set up twins, should I tap an other hole by the pyro and install a boost gauge to read the drive pressure?
Old Dec 9, 2008 | 10:30 PM
dieselfan's Avatar
yes, if you would like to know. use copper tubing on the manifold.
Old Dec 9, 2008 | 10:40 PM
Flatbed24v's Avatar
and any boost gauge will work right, would a 0-60psi cover it. What kind of number would one see with hx35 and a s400 twin setup
Old Dec 9, 2008 | 10:49 PM
dieselfan's Avatar
any psi gauge, even oil. here is a hx35 over a S400 with mach 6.5's.
bnold vbmenu_register("postmenu_2297175", true);
I'm running an HX35 over a 400 right now... I have a 14cm housing on the 35 and a slightly massaged wastegate.
My drive pressures are 1:1 up to 55psi and at 65psi my drive pressures are 68-70psi...
Oh and I never have EGT issues at my HP level..
__________________
2001.5 Dodge 2500 SO pumped HO NV5600 6spd. 4x4: SBC Sprung DD, .043 O-rings, F1 Springs, modified marine gasket,DSS, 5" Turbo Back to Dual 5" Stacks, Mach 6.5 injectors, BD Short Throw, TWINS HX35-14/ S400, ARP Studs, Smarty, Quad Adrenaline, TAG, Coolingmist Stage II, FASS 150/150, 35-12.5 BFG MTs, 16x10 Weld Alloy Rims, Lazarsmith Traction Bars. 4" Inline Packbrake, Onboard air
620/1202 2/22/08
Old Dec 9, 2008 | 11:06 PM
Flatbed24v's Avatar
so is 1:1 good? What is bad and what would be perfect. I take that what ever the final boost psi I end up with the drive pressure gauge should exceed that number
Old Dec 9, 2008 | 11:11 PM
dieselfan's Avatar
yes 1:1 is good meaning at 45psi dp is 45psi.
on a stock turbo when you overboost it at 42psi or whatever the dp is like 70psi something. that is bad, all hot air. thats when the HG goes pop.
Old Dec 9, 2008 | 11:15 PM
Flatbed24v's Avatar
oh I see so is it possible to get the dp under the boost pressure?
Old Dec 9, 2008 | 11:22 PM
dieselfan's Avatar
i think so, before the boost get high, the dp is lower.
Old Dec 10, 2008 | 01:46 PM
BigErksG2's Avatar
i talked to a guy that did a hx35 over a ht3b with a 40cm internal wastegate and had 45psi dp with 55psi boost. the main thing is to get the turbo is its "comfort" range with minimal restriction.
Old Dec 10, 2008 | 11:03 PM
Mike Holmen's Avatar
The Guru
You could also just watch the pyro and you're boost gauge. Usually is around the 1:1 area. If you start seeing more than just a haze, you peak on boost and you're pyro is going to moon, you're over the 1:1 ratio
The drive pressure is always important measurement. It tell if you have more power available in the exhaust. Single turbo will peak and then just restrict the exhaust flow. Its up to the wastegate at the point, if its big enough to dump enough exhaust.
Old Dec 10, 2008 | 11:05 PM
The Guru
The drive pressure is always important measurement. It tell if you have more power available in the exhaust. Single turbo will peak and then just restrict the exhaust flow. Its up to the wastegate at that point, if its big enough to dump enough exhaust, egt's and drive pressure will be at 1:1. If the truck wants more boost (tons of fuel) and there no boost left (hot air), you get more than 1:1
Old Dec 11, 2008 | 09:54 AM
13FOX's Avatar
You can also control your DP with a wastegate. I have a 60mm JGS wastegate that is tapped into the exhaust manifold. Its preset at certain psi to release and then dumps into the hot pipe going into the bottom turbo so that energy is not wasted and will help to spool up the bottom turbo and still keep DP in check. Works very well.
2006BLKMegacab
Jul 3, 2011 08:31 AM
cincydiesel
Jun 11, 2008 01:55 PM
skymiles
Dec 21, 2006 10:05 PM
Hummin Cummins
Feb 11, 2003 12:14 PM
Copenhagenjunkie
Dec 27, 2002 05:45 PM
