Drive Pressure
Old Jul 7, 2007 | 10:34 AM
CTD01's Avatar
Drive Pressure
I want to put a drive pressure gauge in. Do I drill another hole in the manifold? Also what kind of a boost guage do I use? Thanks,
Paul
Old Jul 7, 2007 | 11:00 AM
John Faughn's Avatar
This has got gauges for sale , home page , DTR store ,
As long as its one of the name brands you see a lot in peoples sig. , then it just what your like .
Hot much HPs are your going for ? 50 lbs is a # that many say is going to blow head gaskets , with what you have listed , you may want to start saving for a custom trans , the stock ones do take much HPs .
Your set up may be up to 35lbs + , I like any gauge to have the normal opp. number to be in the middle of the gauge range - if average mid. is 20lbs , then max on gauge should be 40lbs , or 30 - 60 .
Old Jul 7, 2007 | 01:42 PM
bigmack2500's Avatar
Hey CDT01 how are your EGT's with the Mach 6's and htt 62/12 turbo? Looking to getting some
Old Jul 7, 2007 | 02:49 PM
Ph4tty's Avatar
I used some copper tubing and the port for the egt probe with a cheap 0-60 pressure guage to check drive pressure. Do you want to check drive pressure or set up a permanent guage?
Old Jul 7, 2007 | 05:07 PM
CTD01's Avatar
Drive pressure
I want to make a permanant mount one. Wouldnt a regular boost gauge melt?
Old Jul 7, 2007 | 06:38 PM
RowJ's Avatar
You will need copper tubing and, IMO, a filter to keep soot/carbon out of the gauge. Some say not needed but over time I believe you will clog the line. Any air pressure gauge will work and yes, just tap another hole in the manifold.
There is another option I saw on Lazarsmiths truck, but don't know if he (XLR8R) is marketing them not?? Might contact him and see...it's a two in one... single hole set up! Very slick!
http://www.lazarsmith.com/science.html
RJ
Old Jul 8, 2007 | 12:32 AM
NoSeeUm's Avatar
I did mine as it was reccomended to me.
I used about 6 feet of 1/8 inch copper tubing. Most of it in a coil. I made the coil by wraping the tubing around a spray paint can. From there I connected to standard 1/8 inch plastic tubing and then the gaugle. The coil disapates the heat. You will still get some soot, and have to eventually replace the tubing.
Jim
2006BLKMegacab
Jul 3, 2011 08:31 AM
cincydiesel
Jun 11, 2008 01:55 PM
skymiles
Dec 21, 2006 10:05 PM
Hummin Cummins
Feb 11, 2003 12:14 PM
Copenhagenjunkie
Dec 27, 2002 05:45 PM
