Does advancing the timing really help?
Old Dec 15, 2004 | 07:35 PM
matador's Avatar
I am going to try to do it myself. shouldnt be too hard to do.
Old Dec 15, 2004 | 10:15 PM
Ray,IN's Avatar
diesel-kid, I have lost the address(#$%^computor) but diesel injection of Pittsburgh has a series of articles on adding more power to a Cummins engine. The engineer/owner says they retard the timing when adding more HP. They write of a OTR owner/operator with M11 engine running 1,000HP reliability. His story is really neatl!
Old Dec 16, 2004 | 05:05 PM
matador's Avatar
Well I bumped up the timing today about 3 degrees, we will see what happens next trip I make.
Old Dec 20, 2004 | 05:50 PM
masonic-dodge's Avatar
Matador
What do you think of your truck now that you have bumped your timing up? I know that my truck pulls alot better at 17 then it did at 12.5
CRIS
Old Dec 20, 2004 | 06:18 PM
matador's Avatar
Masonic
I only got to take it for about a 5 mile test drive after timint it and the wind was blowing about 35 mph, head wind on the way up and tail wind on the way back. It seemed like it may have had more power but hard to tell with that kind of wind. I will let you know the next real trip I take, as far as gas mileage too.
I been driving a different vehicle since that test drive.
Matador
Old Dec 20, 2004 | 06:21 PM
Matador
You should be able to tell with your right foot and the sound coming from your back tires
CRIS
Old Dec 20, 2004 | 06:22 PM
matador's Avatar
Nope, it didnt do much in that regard. Maybe I need to bump it more eh? It still feels somewhat wimpy to me.
Old Dec 20, 2004 | 06:29 PM
Matador
Just to make you feel alittle better, I took a load if trash to the dump today and had my truck weighted. It was 7280lbs thats alot of tonage Thats a big load to be pushing around with a little SIX BANGER I hope this makes you feel better.
CRIS
Old Dec 20, 2004 | 08:30 PM
Rhino's Avatar
Cris,
7280 with the load C'mon now that is nothing, my truck is 7100 pound with a full tank of fuel and the only load in it is me
Old Dec 20, 2004 | 08:51 PM
matador's Avatar
I think mine is about 7400 with just my topper on it if I remember right.
Old Dec 21, 2004 | 09:55 AM
diesel_kid's Avatar
6660 with two 200 lb guys and a quarter tank of fuel on mine.
But anyways, Matador, what have you noticed so far with your truck and the advancing of the timing? You said that you advanced it 3 degrees from stock, what do our trucks come stock from the factory at?
I would like to know mostly have if affected mileage, hopefully I will be getting a timing kit for christmas, among other tools for the Truck, and I will be able to play around with the timing on the truck.
Also, does advancing the timing anything past 17 degrees really do anything better as far as driving the truck around unloaded all the time, for mileage, power, start up and such. Thanks.
Old Dec 21, 2004 | 10:02 AM
matador's Avatar
I havent driven it more than 5 miles since timing it so I cant tell you much. I think factory is about 14.5 degrees for mine. I used the pump hole window method and simply rotated the vibration damper 3 degrees advance. Its not perfect but its dang close. You dont need any special tools the way I did it.
Matador
Old Dec 21, 2004 | 10:03 AM
Rhino's Avatar
The effects of timing somewhat depends on the pump. The little pumps like more timing. Advanced timing will noticably increase the top end while maybe giving up a little bottom end. The sled pullers like well over 20 degrees for the best performance while running WOT down the track. However I personally would not recommend over 20 degress for a daily driver.
15.5-19 (depending on the pump, setup, and use) seems to net the best results for a daily driver.
Old Dec 21, 2004 | 10:07 AM
matador's Avatar
Thanks for your thoughts Rhino. I figure mine is about 17 to 17.5 now. It is so **** cold now where I live I probably wont know for sure the effects of the bump for a while. It is anywhere from zero to minus 20, with 20 to 50 mph winds.
Matador
Old Dec 21, 2004 | 10:10 AM
Rhino's Avatar
It is not all that uncommon for the factory timing specs to be off a bit, usually retarded. Personally I prefer to know what it is at before I start adjusting it. JMHO
