Diesel-dan, FASS parts needed
Old Oct 16, 2006 | 07:03 AM
getblown5.9's Avatar
my truck came with a FASS and big line kit (the blue 1/2" line with push-lock fittings) so i dunno if this is a FASS part or something the previous owner put together. on the fuel supply the banjo bolt was removed and a brass 90* fitting goes into the VP with a little black aluminum bushing that has 12mmx1.5 style threads into the vp, and 1/2" flare style male threads for the 90 to screw onto. is that bushing something comes with the big line kit? that aluminum fitting felt like plastic, no weight to it and it snapped off at the VP. (from what i hear aluminum and diesel dont mix well and it will make it brittle)
EDIT: after a little research i've found that the threads going into the VP44 is a metric 12mmx1.5 size. summit racing and other race places sell a -8AN (1/2" flare) to 12x1.5 adapter.
Old Oct 16, 2006 | 08:33 AM
Diesel-Dan's Avatar
What you need is a Part number:
DIPF-1001 (Dodge Injection Pump Fitting for a 98.5+ Truck)
If you have 1/2 line, the other owner did that. Our kits come with 3/8" line for that kit. The bad thing is that the DIPF is 12mmx1.5 / 3/8 Flare. This is why he had that fitting in the pump. If you wanted to use our fitting, you would need our PL-1003 (3/8" Flare x 3/8" push lock) and then make a way to adapt it to the 1/2" line you have. Here is a link to our install instructions for the kit on your truck....refer to pgs. 7 & 8 for a list of what is in the kit and part numbers.
Old Oct 16, 2006 | 10:13 AM
thanks for the info dan...it def 1/2" line...just grabbed the piece i cut off and its 1/2" 300psi goodyear. aeroquip/earls makes a 1/2" (-8AN) to 12mmx1.5 adapter in anodized aluminum. i just need to find one and 3' of 1/2" hose local or get it shipped before i dyno on saturday.
with this big 1/2" line i run 13 idle, 10 WOT...do you think i need to get the upgraded spring for high pressure?
Old Oct 16, 2006 | 11:01 AM
Diesel-Dan's Avatar
I don’t think you are in any danger with that pressure. mine runs 14 and 11 respectively.
1/2" hose part number is FL-1002. Just let them know how much you need. Its sold by the foot. BUT honestly, you should be able to find it localy.....unles you are in the boonies.....
Old Oct 16, 2006 | 12:06 PM
just got the fitting and 10' of 1/2" hose from summitt. should be here wednesday...i hope my TST comp comes in so i can use it with my secret squirrel parts that Ph4tty doesnt know about.
Old Oct 16, 2006 | 12:18 PM
Diesel-Dan's Avatar
Sweet ....let me know if i can help ya out any more......
Old Oct 16, 2006 | 12:27 PM
im good...i think the FASS is the ONLY thing left on my truck that came with it when i bought it that i havent replaced or broken yet...so i guess thats a testament to its quality
banks ottomind-gone
banks wastegate and 14 housing-gone
banks gauges-gone
banks 4" exhaust-almost gone, 3' left between DP and stacks
BD short shift-broken and replaced
Old Oct 16, 2006 | 12:40 PM
BigBlue's Avatar
I seem to notice a pattern in your list.
Old Oct 16, 2006 | 12:46 PM
but its the best on the market blue!
notice my sig now contains no banks and some of the ph4tty's secret squirrel parts. he cant find out about them until after this weekends dyno tho so SHHHH!
Old Oct 17, 2006 | 12:47 AM
Ph4tty's Avatar
ji hope my TST comp comes in so i can use it with my secret squirrel parts that Ph4tty doesnt know about.
What the duece??!?
Truth be told I saw secret squirrel parts listed on Joefarmer's sig and I had to have one!
At spring fling my secret weapon was a bottle of redline addtive in the fuel
Old Oct 17, 2006 | 12:48 AM
Ph4tty's Avatar
And to think I almost didn't look at this thread
Old Oct 17, 2006 | 03:43 AM
i dont use drugs...its not me. im a #2 only kinda fella :P
oly 4 days...hope you know is all friendly
Old Oct 17, 2006 | 07:17 AM
BigBlue's Avatar
No such thing as friend in war.
Old Oct 17, 2006 | 07:33 AM
come on now...im not that mean...i am gonna be letting him borrow my TST comp this weekend so he can dyno his new cheaters i mean parts
plus i gotta be nice so he will vote for me for Truck of the Month! and i take it easy on him cuz the poor guy was shorted a t-case, axle and driveshaft when i bought his truck. LOL
in all seriousness, ph4tty which day are you coming again this weekend? the TST should be here friday
Old Oct 17, 2006 | 11:34 AM
Ph4tty's Avatar
I'll be there first thing saturday. Its supposed to be sunny and 60 degrees.
