Delivery Valves Question...
Old Sep 25, 2006 | 05:13 PM
Chrisf's Avatar
This maybe a stupid question but can you drill out or modify the stock delivery valves to add more fuel?
Thanks
Chris
Old Sep 25, 2006 | 08:30 PM
JKM's Avatar
JKM
Short answer, no, if you saw a delivery valve taken apart , you would understand. About all you can do is swap them out for larger ones, which , in your case , they don't come much bigger , unless you go to lazer cuts , which i think are modified stock DV's?
Old Sep 25, 2006 | 09:57 PM
cumminsdriver635's Avatar
Some machine shops can cut them for you.
Eric
Old Sep 26, 2006 | 01:00 AM
Chrisf's Avatar
are there any specs around to let them know how to cut them...
Old Sep 26, 2006 | 01:03 AM
Not that I know of. All I really know is that a guy here in Danville can cut them,a nd has for a few guys around here.
Eric
Old Sep 27, 2006 | 12:21 AM
12valve's Avatar
i believe it "could be" similar to a problem I had a time ago...
I live far away from any shop in Usa who do Head Oring, and I asked on this board how it has to be done, and what machines I would need.
Only answer i got was: NO! the machines would be very expensive, and you could not do it by yourself... etc...
then a great guy at a diesel performance shop told all the specs on cutting the grooves, wire and everythig, and found a shop 4 km away from me, who can do it!
There are always those people who think things are impossible!
now im not saying its the case here with the Dv's, as I have seen a DV myself.... all you need to know is how to cut and have the right equipment to do it!
i would really appreciate to hear if its possible too!
cumminsdriver635: what does he charge??
Old Sep 27, 2006 | 12:44 AM
I dont know what he charges to be honest. Its not over $100 i dont think.
Eric
Old Sep 27, 2006 | 08:03 AM
gunracer1's Avatar
it is pretty simple to cut them with the right set up. i have been thinking about grinding a set on a tool grinder i have at work.
Old Sep 30, 2006 | 04:52 PM
12valve's Avatar
Now that'd be great!
what kinda tool grinder is it7 do you think makin it work.
and, where is the difference from stock to cut DV's?
Old Sep 30, 2006 | 08:52 PM
Sidewinder's Avatar
I have heard all kinds of things about delivery valves, I know where they go and what they do BUT I have no idea what they look like. Does any one have a picture of one? And how about a picture of the difference between a stock one and a modified (laser cut) one.
Old Sep 30, 2006 | 09:29 PM
JKM's Avatar
JKM
I don't have any pictures right now , but i can take one tomorrow if you want , but it will be of my 131's that i took out.
Old Sep 30, 2006 | 09:43 PM
lonewolf42262's Avatar
I work at a large machine shop, and after finding cores I have made a few sets of EDM injectors, and am awaiting some spec for DV's the largest problem I run into is not enough cores for testing and ofcourse its very hard to get specs to use for reference. But with the tools its easy to accomplish if you know what specs to go by
Old Oct 3, 2006 | 03:17 PM
12valve's Avatar
thats cool! so how did your EDm injectors turn out to work? I have some cores!
and could possibly anyone load a high resolution pic of a lazer cut dv?
Old Oct 3, 2006 | 07:31 PM
12valve's Avatar
Here you go i went out and took some pics of a DV out of a 160 Ppump
click thumbnail for larger image
Old Oct 10, 2006 | 09:18 AM
tmacie's Avatar
Sweet, thanks for the pics....now just for some specs and what to cut.
Travis
or at least pics of bigger DVs.
