dana 80
Old Oct 30, 2005 | 10:48 PM
12vstrokethis's Avatar
dana 80
i have a Dana 80 in the rear on my truck which is a 3/4 ton the single. What is the cheapest and best posi track not lock/spool? What spline axle shafts do i have in the Dana 80? How good are factor posi track?
Old Oct 31, 2005 | 06:15 AM
CTD NUT's Avatar
All Dodge D80's were equipped with 35 spline shafts. By far, the best limited slip diff for the D80 was the factory Dana Powr-Lok. This was one of two LS diffs that were factory installed by DC, the other being the inferior Trak-Lok. If you are looking for the most durable and best performing LS for your D80, get yourself a Plok.
Old Oct 31, 2005 | 08:34 AM
TxDiesel007's Avatar
Powertrax?
anyone? ive debated this myself.. I have a really good limited slip on my 1996, Just dunno which of the two it is, track lock or powerlock.... does it depend on rear end ratio?
Tx
Old Oct 31, 2005 | 08:43 AM
CTD NUT's Avatar
If you have the original factory equipped LS in your 96 and it continues to work well, I can almost guarantee you that it is a Plok and not Tlok. Tlok's have a poor reputation for durability and longevity. Powertrax diffs are auto lockers not limited slips.
Old Oct 31, 2005 | 09:24 AM
HOHN's Avatar
My 02 has a trash-lok. Talk about a factory worthless POC. I thought it was a p-lok, but it's not.
YOu can tell because a trash-lok has has the cross shaft nested in a perfectly matched groove. The P-lok has the cross shaft in a "V" shaped groove that causes a ramping action against the clutches.
Old Oct 31, 2005 | 10:20 AM
P Kennedy's Avatar
Over the past few months my LSD started to chatter even after adding proper plus amounts of posi slip fluid, then there was an accident the LSD fell out and a Greenberg Machine Detroit Locker fell in. We now have 2 modes locked or open on a corner coasting, we now have Posi-Traction, problem solved. Saved $600 on rebuild kit for junk LSD, For Sale 1-used LSD. PK
tankeryanker
14
Jan 19, 2005 04:18 PM
Mechanos
Jan 22, 2004 12:45 PM
matthopp
Nov 21, 2003 04:49 PM
mcevins
Jul 3, 2003 02:06 AM
Stamey
Apr 18, 2003 10:34 PM
