custom 200HP injector ???
Old Aug 9, 2008 | 02:49 PM
12valvetom's Avatar
I found injectors 5x.017 and the guy said they are 200 hp injectors could they be or are they bigger than ddp 140's?
Old Aug 9, 2008 | 08:04 PM
HOHN's Avatar
I'm not familiar with the "redneck injector sizing system" of hole x diameter--but .017 is a pretty big hole for an injector. If that was 7x .017 we'd be talking about LOTS of fuel!
Old Aug 10, 2008 | 05:35 PM
24valvepuller's Avatar
I thinks the "redneck" way is better than most of the vendors way of doing it. 5x17 will flow alot of fuel and more than that little super b will be able to use
Old Aug 10, 2008 | 06:58 PM
mdavlee's Avatar
435s from new era or somebody like that are 5x.014 and are rated at 140 hp so they could be pretty close to 200
Old Aug 11, 2008 | 10:05 PM
Rods's Avatar
I thought Scheids and Haislys were to far north for rednecks ? But what do they know its not like they been doing this sence ??? Only the ones who sell by HP know little what they have only cause they can sell a HP #
BTW CEZAR whats your method
Old Aug 12, 2008 | 06:42 AM
HOHN's Avatar
Those who think that orifice size and count are the only specs that affect hp have a little more to learn...
jmo
Old Aug 12, 2008 | 07:17 AM
2whistlers's Avatar
True but hole size and diameter should be listed with every injector sold, imo.
Old Aug 12, 2008 | 04:12 PM
Rods's Avatar
jmo
So whats your injector companys name and number I will tell Dan Scheid to call you
Old Aug 12, 2008 | 07:06 PM
dieselfan's Avatar
Old Aug 12, 2008 | 07:30 PM
Morse's Avatar
I don't feel the vendors should be asked to give their specs. That partially gives away their methods. HP numbers are more than enough to go by when building a combination. Some vendors may be able to use a much smaller hole, and get higher hp than others. Stating a hole size tells very little to the average customer.
Old Aug 12, 2008 | 08:10 PM
dieselfan's Avatar
are you talking about pintail work and lift?
Old Aug 12, 2008 | 09:50 PM
Rods's Avatar
True holes arnt everything there are ways lets say machine shops do .. Vendors dont , funny how about 75% of aftermarket injectors come from 1 shop
Old Aug 13, 2008 | 12:14 AM
Tate's Avatar
I'd suggest teh exact opposite. Our choices are so devoid of specs, its hard to actually get an idea of how anything works without someone elses first hand experience. Turbo's is a prime example. We go by compressor inducer size, and exhaust housing size, and now turbine size now that we have a second option. No maps, they don't give us the trim or major diameter of the compressor wheels, no A/R's. Just rough estimates of what that charger will support. I'd be much happier to have to swim through specs I don't yet understand than be given one or two general specs. JMO.
Old Aug 13, 2008 | 01:22 AM
braxton357's Avatar
Yep. Assuming the injectors were built using the same methods, I'd much rather have the specs than "100hp". Once you're past basic upgrades, that means little. Just like you say, stating it's a "500hp turbo" means nothing unless you're just a casual shopper with too much money to spend. Makes it hard to compare anything...
Old Aug 13, 2008 | 05:23 PM
HOHN's Avatar
I believe you are referring to a PINTLE, correct?
Injector flow is ultimately determined by only two factors: the hole area and the injection pressure. The use of additional, smaller holes seems to be only of marginal significance in power production and atomization.
Cummins calls this spec "cupflow"-- literally how much fuel will flow through the nozzle tip under standardized test conditions. Units are in Lb/hr.
But POWER production for a given cupflow has a good amount of variance. There are simply MANY factors at work that determine the benefits of a certain nozzle design relative to flow.
Injectors are designed to work with a certain piston crown, in general. This is because the crown affects how the flame propagates through the cylinder, and thus how cylinder pressure and temp will rise relative to time and crank position.
If I advance the timing of the injection event, the ideal spray angle changes, and I have to inject the fuel farther down into the cylinder to preserve the relationship between piston bowl position at SOI (start of injection).
Flow VELOCITY matters a lot too. Consider Don's famous Mach 6s injectors. They flow a pretty good amount (which I don't know). They make tons of power. Yet they don't have 9 or 11 or 15 holes. They have 6 or 7, which is the same or less than a 7-hole RV injector.
Doesn't atomization suffer if you don't have more holes? Moreover, should better atomization make more power?
Yes and no. Atomization is important, but so is velocity. This is because a good portion of the "atomization" happens when the burning stream of fuel hits the piston crown and splashes all over the place.
This is why Don's early injector experiments with the 11 hole nozzle made great power and had good response until boost hit 40psi or so, then all of a sudden they would smoke like nuts and power would fall of radically. There was simply not enough velocity of the fuel spray.
Another huge variable is the shape of the injection pressure curve-- i.e., how the injector goes from pop pressure to closing pressure and all the points in between for a given volume of fuel.
This can actually have an affect on the RPM at which injection efficiency is optimized. At higher RPM, you have less time to inject the charge and you need a more aggressive rate of discharge (compressed timeframe). This is one of the reasons that larger injectors will seem to help an engine pull past the factory 24V 2700rpm defuel point, even without software manipulation like a Drag Comp would do. It's not that only reason, but it's ONE of the reasons.
The penalties to be paid with bad injector design can be pretty steep. Aside from engine failure if a Nozzle fails, you have the possibility of washing the oil off the cylinder walls and increase wear at the top ring reversal (already a high wear point because of the absence of a hydrodynamic oil wedge for the ring to ride on).
Nozzle tip temperatures have to be managed not only because of the effect on thermal fatigue (and thus, nozzle failure), but also because of possible coking when carbon fouls the spray holes.
There's a joke at Cummins that we wish we could make injectors out of carbon fouling, because it seems to withstand the erosion of fuel injection pressures over 2200 bar!
So, when a person take a simplistic "dimension X hole count=hp" view of injectors, it may seem to make sense.
But a serious analysis of the injection process reveals that there's a heck of a lot more to it than that. That's why, in some cases like with Don't injectors, it's just a lot easier to accept the manufacturers advertised HP rating, assuming it's valid.
With a quality injector maker, the HP rating is pretty valid. With a company whose research is a little less stringent, things can get pretty dicey.
Justin
