Current build. Almost done.
Old May 17, 2013 | 01:20 AM
Common's Avatar
Big thanks to infidel for always helping me out and to Lil Dog for the support and info.
I decided it was my time to build the truck of my dreams. I know it sounds lame, but I've always wanted a Cummins powered 12 valve with all the trimmings.
I just never pulled the trigger on doing much other than my #10 plate.
Bowser Performance is doing the build for me and I couldn't be happier with the service. Bill Bowser is a super awesome guy and really takes care of you.
Here's a list of everything I've been doing over the past month.
- New Water Pump
- New Vacuum Pump
- New Power Steering Pump
- New Oil Pan
- New Head Studs Installed
- New Front Main Seal
- New Rear Main Seal
- Completely Clean Engine Bay
- Completely Strip and Clean Engine
- 4K GSK
- 60lb Valve Springs
- Air Dog 150 Installed
- Delete Stock Fuel Filer Assembly
- Delete Stock Lift Pump
- Preheater Deleted
- New Fuel Lines
- Fuel Gauge on New 3 Gauge Pod - Paint Matched
- New Boost Line
- 5 x 18 Injectors
- New Bearings
- All New Gaskets
- Aurora 3000 Turbo
- PEAK Intercooler Boots
- Timing Advanced and Engine Tuned
In the fall I'm adding a South Bend Double Disk, delivery valves, Aurora 5000 compounds, cam and a few other things.
Feels good to build the truck you've always dreamed about.
A big thank you to this site and all the members for all their help over the years.
And a big thank you to Patrick over at ATS diesel for going above and beyond for me.
I'll post more when it's done.
Old May 17, 2013 | 12:17 PM
Tate's Avatar
Whats your power goals? You've got some awfully big injectors for even those compounds, let alone the S300G currently.
Old May 17, 2013 | 02:20 PM
Common's Avatar
Haven't decided quite yet.
Haven't put delivery valves in, so those injectors will only flow so much.
When I firmly decide, I'll have the injector to support it.
Do you like that Big Stick cam? I was thinking of grabbing one.
Old May 17, 2013 | 08:39 PM
Tate's Avatar
Made a noticeable difference. Dropped spool up from 2000 to 1700 with a 66/73 turbo. I'll likely go to a 188/220 for the next one in the daily driver.
Huntsalot
Mar 22, 2007 07:17 AM
dodgeguy71
Apr 6, 2006 12:59 AM
SmokinFive9 4x4
Oct 27, 2005 10:49 PM
Palmetto_kid
Oct 7, 2002 03:49 PM
