Crossover tubes
Old Apr 15, 2007 | 01:48 AM
CTD01's Avatar
Crossover tubes
Will I get any gain with .120 crossover tubes? I dont know much about these but what will they affect if you dont have bigger lines? Thanx,
Paul
Old Apr 15, 2007 | 03:00 AM
BigBlue's Avatar
I've heard a truck with the bigger tubes in them. It idled very poorly. Unless your well over 700hp I don't see a need for them and even then I don't see a need for them. You can make 600+ on the stock tubes with ease.
Old Apr 15, 2007 | 10:16 AM
Ph4tty's Avatar
I beleive Haisley says your truck won't idle with lines that big.
Old Apr 15, 2007 | 10:30 AM
Jetpilot's Avatar
The tubes won't add any power. The big injector lines will cost you HP.....
Old Apr 15, 2007 | 12:24 PM
CTD01's Avatar
crossover tubes
I see that people drill them do they drill right through the little cross hair at the end or just up to it. I saw a set cheap so i figured I'd try them. You guys think it wouldnt idle? TIA,
Paul
Old Apr 15, 2007 | 02:27 PM
BigBlue's Avatar
Oh it'll idle. It'll sound like a big pulling truck but it'll idle.
Old Apr 15, 2007 | 11:27 PM
Ph4tty's Avatar
I think it depends on the size. Here's your sign:
LINES AVAILABLE AND IN STOCK- .084 AND .093 FOR 12 OR 24 VALVE, .120 CAN BE ORDERED FOR THESE APPLICATIONS, NOT RECOMMENDED FOR THE 24 VALVE (ENGINE WILL NOT IDLE). CLAMPED TOGETHER AND READY TO GO!
http://www.haisleymachine.com/PERFOR...20PRODUCTS.htm
cbrahs
0
Aug 24, 2011 12:30 PM
cbrahs
0
Aug 24, 2011 12:28 PM
cbrahs
0
Aug 24, 2011 12:27 PM
Derek Roch
Apr 8, 2010 07:51 AM
2001smoker
Sep 22, 2009 03:39 PM
