Could puck cause dead pedal.
Old Jun 19, 2008 | 08:08 PM
babyjoe's Avatar
I have been having intermittant dead pedal, Have new lP and Holley blue plus lift pump are both new.Could the power puck cause a dead pedal. I know it runs to the map sensor and have unplugged map sensor before and if you do that it will give you a dead pedal. Just hunting for a cure...I unplugged it before work so I will run it awhile and see...
Old Jun 20, 2008 | 06:40 PM
babyjoe's Avatar
anyone got an idea??
Old Jun 21, 2008 | 12:19 PM
ironbutt's Avatar
It could have helped to do it, but with 124k mi it could just be it's dying on its own. My first VP44 died about 40k after I put on the power puck. It died at about 87k but the intermittant dead peddle started about 75k. I also had a "pusher pump" between the tank and the stock pump. Good luck.
Old Jun 21, 2008 | 08:55 PM
nickg's Avatar
Do a search, I believe I've read that the puck comes apart...why not unhook it entirely, and run it stock to see if you have any issues
600 Megawatts
Mar 26, 2008 07:09 PM
tex23455
Feb 18, 2008 07:57 AM
BIGDAN65
16
Jan 23, 2008 10:02 PM
vikingsven
Oct 29, 2006 08:28 PM
billygoat02
Dec 30, 2005 09:19 AM
