Which controler box
Which controler box
Hi all, I have been reading, and using your knowledge from this board for alittle while now, all great stuff. Here is the deal, I don`t tow anything, I don`t drag anything, I don`t mud anything. I just commute about 120 miles a day. I like to do the onramp drag alittle, but I really would like to get a few more mpg than I am getting now which is 20-+. I don`t want very much smoke, not real politically correct here in the LA basin. I`m sure there is advice out there. Thanks for responding. Mark.
I have used smarty, edge ez, and the adrenaline and now the ts mvp and by far like it the best it has a controller **** like a volume **** on your radio it packs a very nice punch better than the others in my opinion (for a none wire tap box) and is the only box I have used that actually saw a good increase in mileage I really like it and is priced right
Quadzilla xzt+ is just a 65 hp box that is supposed to raise mileage a couple of miles but I never drive it right. But for a few hundred more you can just get the adrenaline and you will have the power if and when you want it.
Anything with timing should help a bit with mileage. The TS box sounds promising and there are lots of favorites if you want to read through the forums. I've been running a smarty which offers a lot of tuning options for fueling and timing so you can dial it in to how you want your truck to run.
i really like my adrenaline it has alot of options as well, it is usb updateable and there are tons of differant tunes that u can try. i havent had the will poer to try it but i have talked to some guys that seen 2+ mpg on power levels 1 and 2.
Diesel Fumes
Apr 4, 2004 09:39 AM
Trusty Steed
Jan 29, 2004 03:55 AM
