comp questions??????
Old May 15, 2005 | 08:06 PM
duallydave's Avatar
Question comp questions??????
hi guys,i just bought a used comp box,havent installed it yet,i have a van akken box rite now,since the van akken only plugs into the pump and the comp plugs into the map sensor and such can the 2 be used together?is there any benifit?would the timing advance be to much?also if i dont pierce the pump wire with the comp are the 5 settings and sub settings available just without all the fuel increase?ive read the comp will act likea ez without piercing the wire,is this true?thanx in advance.
Old May 15, 2005 | 08:58 PM
SuperDave4x4's Avatar
With the pump wire not pierced it will only act like an EZ, but you can play around with the higher levels but it wont increase fueling.
And have you beefed up your tranny????
Old May 15, 2005 | 09:41 PM
duallydave's Avatar
i havent got a new heavy clutch yet but its in the budjet,the stocker is working good,so the settings will work without piercing the pumpwire?thats cool,has anyone stacked a comp with a van aaken?will it cause any problems?thanx guys
MoreSmoke
Jan 7, 2004 09:40 PM
James Lucas
14
Aug 29, 2003 11:24 AM
hellotbone
Jul 12, 2003 12:58 AM
hellotbone
18
May 16, 2003 04:40 PM
danlit
Feb 13, 2003 10:53 AM
