comp problems
Old Dec 7, 2002 | 12:05 PM
99purplecummins's Avatar
comp problems
hi all, long time since i asked a ? on here :P . we got the comp box and everything plugged in and when we tried to start the truck, we got NOTHING!!!!!! it wouldn't crank over so i had this little idea of wut if i took the sensor off (the one closest to the front bumper of our 99) ad then told him to try to fire it up. guess wut happened, IT RAN!!! wut gives???? do i ned it plugged in or can i leave it off or wut should i do (its the data link i think) if anyone has had this proble and knows how to fix it PLEEEEEEEEEAAAAAASSSSSSSSSSSEEEEE tell me cause i'm going insane tryig to figure this out. once again, thanks for all the help u have given us,<br><br>mike
Old Dec 8, 2002 | 11:44 AM
PourinDiesel's Avatar
Re:comp problems
Call Edge Products.<br>They'll set you straight.<br><br>www.edgeproductsinc.com<br><br>--Justin
Old Dec 9, 2002 | 11:23 AM
doug's Avatar
Re:comp problems
yours is either hooked up wrong or you have a bad box. make sure you ground the box out under the hood. sounds like, for whatever reason, your box is holding down the fueling instruction bus. power up your box properly and then call edge.
Old Dec 9, 2002 | 06:36 PM
Bob Wagner's Avatar
Re:comp problems
I wonder if Edge Products has a burn in procedure before the box is shipped.<br><br>Sure seems to be a batch of problems lately
Old Dec 9, 2002 | 08:21 PM
99 cummins's Avatar
Re:comp problems
Me and young un finally got this thing running, we undid all the plugs on the Comp and sprayed em down with terminal cleaner, put em back and it fired right up. something so simple.
Old Dec 10, 2002 | 10:31 AM
BigBlue's Avatar
Re:comp problems
Mine fired right up first time with no hitch. Only problem is that it surges after I run it on 3x3. Oh well.
Old Dec 10, 2002 | 11:23 AM
99 cummins's Avatar
Re:comp problems
Last night I was noticing that at idle it runs a little rougher, has that slight bobble to it. Can't really test it on the road yet, it tends to leave my stock tranny in the dust. Even at 65mph down the road I can turn this box on and any pedal I give sends the clutch on a merry go round. Even after reading about this comp in all these threads it is still hard to imagine the increase in power that it gives.
MoreSmoke
Jan 7, 2004 09:40 PM
James Lucas
14
Aug 29, 2003 11:24 AM
hellotbone
Jul 12, 2003 12:58 AM
hellotbone
18
May 16, 2003 04:40 PM
danlit
Feb 13, 2003 10:53 AM
