Comp into a drag comp?
Old Aug 29, 2008 | 01:17 PM
Flatbed24v's Avatar
I have the comp box and was wondering if there is a way to upgrade it to the drag comp, if so what does it cost and how do I do it.
Old Aug 29, 2008 | 02:14 PM
scottsjeeprolet's Avatar
You gotta send it into Edge to have it upgraded. I think it's about $100.
Old Aug 29, 2008 | 03:27 PM
Sea:\>Drive's Avatar
Details are on their website in a PDF file I believe (not that I've ever looked into that)
Old Aug 29, 2008 | 05:50 PM
J Lent's Avatar
Go to www.edgeproducts.com then drag upgrade form, fill it out, send the comp, form & check to Edge. You can also call them & they will give you a RMA# to send it in.
Old Aug 29, 2008 | 06:00 PM
Flatbed24v's Avatar
do I just unplug the box that is in the cab and send that in or do I need to send any of the wire harness with it
Old Aug 29, 2008 | 06:03 PM
mishkaya's Avatar
I believe they only need the box, however if you don't unplug the harness you will get a check engine light.
mishkaya
Old Aug 29, 2008 | 06:07 PM
J Lent's Avatar
mishkaya
I only sent the box, but like said....you gotta unplug the harness from your map sensor & plug in the stock harness.
Old Aug 29, 2008 | 06:18 PM
Flatbed24v's Avatar
thank guys that helps me out.
Old Aug 29, 2008 | 06:30 PM
Floorman's Avatar
better replace that clutch bigger turbo
Old Aug 29, 2008 | 06:40 PM
oaborbag's Avatar
when I sent mine they wanted the wiring harness too, they sent me back a new harness so I didn't care, but I would say its definitely a good upgrade, was night and day.
Old Aug 29, 2008 | 06:49 PM
Flatbed24v's Avatar
how would this hot upgrade compete with the guys running quad. Adrineline(I can't spell) will I be able to keep up or just eat smoke.
Old Aug 29, 2008 | 07:01 PM
mishkaya's Avatar
If you have essentially the same mods as they do, I believe you will be able to hold your own. I had the comp (not hot) stacked with the smarty prior to the Adreanaline, and I personally prefer the Adrenaline to my stack, but for me it was more a matter of driveablilty more than just shear HP. I never did dyno the truck with the Comp/Smarty so I can't tell you the difference there. I still believe there can't be that much difference in HP.
mishkaya
Old Aug 29, 2008 | 07:02 PM
J Lent's Avatar
I went from the Drag comp to Adrenaline. I like the Adrenaline much better, more responsive off idle, longer fuel stretch [I got 3200 with Drag comp, Adrenaline 4k] I think you will be eating smoke, sorry.
Old Aug 29, 2008 | 09:10 PM
Moules's Avatar
NOT!!! had the adrenaline, now back to the old school drag comp. on a dyno, drag comp by 20hp. on the g-tech, drag comp by .4. dont fall for the greener grass. drag comp on my truck pulls harder.
Old Aug 29, 2008 | 09:21 PM
dodge_24's Avatar
how do u know if u have the hot version box
and ive heard on the forums that there is a 10.0 version mine has the 7.0 is that good or bad
does edge sell the wire harness for the comp need a new one
thanks
