Commander/Juice question
I know the Commander uses the factory map, but does the Juice as well? Also, do either of these have a solution for a boost source if the day were to come when I maxed the map sensor out? Finally, how many bar is the factory map sensor?
My Juice harness plugged right into the stock MAP sensor. I'm not exactly sure what exactly ya mean by a boost source, but with the Juice's Attitude monitor you can adjust your low boost fueling at each power setting.
The MAP sensor on our trucks has a limitation on how many PSI it can read, but how much that is I'm not sure, and if one were to reach that point the commander would just flat line at the max reading no matter what. My question is, what can someone do that hits that max value?
airforceivan
24
11-25-2007 10:11 AM
cowboy717
07-15-2007 11:05 PM
rjm022
11-23-2006 11:29 AM
stock03
11-09-2006 11:27 PM
