Codes on Smarty
Old Apr 18, 2007 | 04:20 PM
CapnRam's Avatar
Codes on Smarty
Just did a check on the smarty and it says i have 3 DTC codes... P1693,
P0602 and a P1682. I had these the other day and cleared them, and there back. Trucks running great, no check engine light or anything, charging system is showing over 14 most of the time after heaters shut off?? any ideas?? thanks
Capn
Old Apr 18, 2007 | 09:20 PM
graphitecumnz's Avatar
0602 is the standard code created by any downloader.... basically, it's normal and nothing to worry about.
Old Apr 18, 2007 | 10:27 PM
Tiger Rag's Avatar
I know 1693 is a companion code and 1683 may be too. Nothing to worry about with the Smarty.
Old Apr 18, 2007 | 10:30 PM
Ph4tty's Avatar
P1682 means you need to check your alternator. Charging system voltage to low.
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
StormTrooper
Mar 28, 2005 09:17 AM
