Code 0216
Old Oct 11, 2008 | 04:38 PM
dsl21's Avatar
Code 0216
Hey guys,my truck smokes white smoke like crazy,at startup,and idles down to about 450-500 rpms,bout wont run,and its showing a 0216 and 0602 code.If I turn it off ,it runs ok for a bit,then does is again.Is it a vp???? still has the stock one with over 200 k on it
Old Oct 11, 2008 | 04:59 PM
mishkaya's Avatar
0216 is the death code for a VP44, so my guess is that it is indeed dead, unfortunately.
mishkaya
Old Oct 11, 2008 | 05:28 PM
smokinram99's Avatar
200k on 1 VP? lucky you!! P0216 is the death code, yes...
Old Oct 11, 2008 | 06:50 PM
dsl21's Avatar
dangit!! no wonder my fuel milage has gotton crappy!! I know this has been beet to death,but where is the place to get a good pump,worth the money??
Old Oct 11, 2008 | 08:50 PM
mishkaya's Avatar
midwest fuel injection seems to be the best place for most.
http://www.mwfi.com/
mishkaya
Old Oct 11, 2008 | 08:59 PM
PaulDaisy's Avatar
I bought mine off of Ebay, but I called first to try to get a feel for the shop. Turned out to be Pensacola Diesel with a good rep, and I bought the VP. And it runs just fine for 1.5 years now. Was less than $950.
Old Oct 11, 2008 | 09:14 PM
dsl21's Avatar
does anyone think that blue chips pump is worth the extra 600???And also would I be better going wit a so pump ,or staying wit my ho??
Old Oct 12, 2008 | 04:56 AM
mishkaya's Avatar
I won't comment either way on the blue chip pump, it's your money, it's your call. However, if you plan on increasing your HP substantially, then definitely go with an SO pump, you will be glad you did. If you intend to keep the truck relatively close to stock as far as HP, then just keep the HO pump.
mishkaya
Old Oct 12, 2008 | 06:39 AM
P.J's Avatar
P.J
My other truck made it to exactly 68K.
Old Oct 12, 2008 | 07:42 AM
heykw's Avatar
why not change over to a p7100. I would think that it would not cost that much more and you have not bought any boxes or chips as of yet so u are ahead of the game in that respect. I am sure someone can chime in that has done this swap in the past. Good luck
Old Oct 13, 2008 | 01:57 PM
PaulDaisy's Avatar
I don't know if BC is worth it; I was told that all Bosch authorized shops refurbish VP44 using the same part kits and the same test stands, so any authorized shop is a good source for a stock VP.
If you're going HR, that is a different story.
HOdiesel80
Jun 10, 2005 07:53 PM
Gear Poet
Oct 7, 2004 10:15 AM
scuzman00
Sep 7, 2004 10:00 PM
TE-44
Jul 31, 2004 10:29 PM
j
Mar 9, 2004 11:45 AM
